Posted February 2, 20196 yr comment_567235 My original door fits fine but has dents so I picked up a replacement door Problem is I can’t get the door to line up at the top and bottom unless I take out the bolts on the bottom bracket and move the door out. The only way I can think about fixing this is cutting out the door captive nuts and welding them where I need. Original door New door Bolt alignment to get the door flush as you can see this is beyond enlarging the holes on the brackets Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/61520-78-door-alignment-help/ Share on other sites More sharing options...
February 2, 20196 yr comment_567241 are here no shims on the body side of the hinge that you can play with? Link to comment https://www.classiczcars.com/forums/topic/61520-78-door-alignment-help/#findComment-567241 Share on other sites More sharing options...
February 2, 20196 yr Author comment_567252 Is it ok just to shim the lower hinge only at the body? The top hinge needs to stay as close as possible to the body Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/61520-78-door-alignment-help/#findComment-567252 Share on other sites More sharing options...
February 2, 20196 yr comment_567262 On 2/2/2019 at 12:10 PM, ryanotown22 said: Is it ok just to shim the lower hinge only at the body? Sure it's okay, most of the hinges by now have some kind of slop in them anyway. Link to comment https://www.classiczcars.com/forums/topic/61520-78-door-alignment-help/#findComment-567262 Share on other sites More sharing options...
February 2, 20196 yr comment_567279 You need to set the door with the fender on. Both ends need to line up. Get the fender end of the door right first. Use shims if necessary. One, or both or none is fine. If the rear doesn't line up, twist it like I illustrated in my "Lily" thread Link to comment https://www.classiczcars.com/forums/topic/61520-78-door-alignment-help/#findComment-567279 Share on other sites More sharing options...
April 28, 20196 yr comment_574384 Thanks for this thread. I just followed that advice and my door does now line up pretty well now. I also have a tear at the front top of the door to fix again which I thought I'd finished but it's worth it! Link to comment https://www.classiczcars.com/forums/topic/61520-78-door-alignment-help/#findComment-574384 Share on other sites More sharing options...
April 28, 20196 yr comment_574424 On 4/28/2019 at 11:43 AM, jonbill said: Thanks for this thread. I just followed that advice and my door does now line up pretty well now. I also have a tear at the front top of the door to fix again which I thought I'd finished but it's worth it! They all seem to crack there, probably all the door slamming. Link to comment https://www.classiczcars.com/forums/topic/61520-78-door-alignment-help/#findComment-574424 Share on other sites More sharing options...
April 29, 20196 yr comment_574444 On 4/28/2019 at 10:16 PM, grannyknot said: They all seem to crack there, probably all the door slamming I always figured this came from using the window frame ('sash') as the pull (or push) point for closing the door. Maybe, though, it's just because of the impact loads when window frame meets weatherstrip at high speed. Link to comment https://www.classiczcars.com/forums/topic/61520-78-door-alignment-help/#findComment-574444 Share on other sites More sharing options...
April 29, 20196 yr comment_574446 It's an interesting situation. The current project has the same cracks. The window frame is bolted to the inside shell of the door. So I am not sure it applies pressure to the outer skin in order to crack them apart. Anyone else have any theories? Link to comment https://www.classiczcars.com/forums/topic/61520-78-door-alignment-help/#findComment-574446 Share on other sites More sharing options...
April 29, 20196 yr comment_574449 Can you post a picture panned out? Is it a 240Z? Link to comment https://www.classiczcars.com/forums/topic/61520-78-door-alignment-help/#findComment-574449 Share on other sites More sharing options...
April 29, 20196 yr comment_574463 On 4/29/2019 at 1:13 AM, Zed Head said: Can you post a picture panned out? Is it a 240Z? Here's a slightly wider angle. It's a 260.It looks like its a weak spot because the door skin joins differently here - elsewhere it's a fold over seam, but here it's not folded over. Maybe it's a brazed joint?I thought mine cracked originally with a bit of corrosion and with the way the hinges were shimmed the door was hitting the seal on the rocker under this point and so shutting the door was stressing it.I hope I've sorted it now, the crack and having to slam the door really detracted from driving it. Link to comment https://www.classiczcars.com/forums/topic/61520-78-door-alignment-help/#findComment-574463 Share on other sites More sharing options...
April 30, 20196 yr comment_574541 Here's my crusty 76 280Z. It's folded all the way, you can see where the roll over starts. That's the same spot you showed but from the inside. Is yours an early 260? I've seen rumors that Nissan changed the sheet metal on the "big bumper" cars and that's another reason that they're heavier. Link to comment https://www.classiczcars.com/forums/topic/61520-78-door-alignment-help/#findComment-574541 Share on other sites More sharing options...
