May 15, 200321 yr comment_37478 Originally posted by Gav240z In case you don't know I use a PIPE which I slide over say a rachet to give extra torque for turning the bolt. I had to do this with a set of CV joints on my old corolla. Otherwise they were just on too tight. I use the round end of a spanner to fit tightly over the head of the bolt or nut then use a heavy rubber mallet on the other side Perhaps a little less civilised... Link to comment https://www.classiczcars.com/forums/topic/6158-what-to-save/?&page=2#findComment-37478 Share on other sites More sharing options...
May 16, 200321 yr comment_37620 drunkenmaster - The transverse links and control arms aredifferent things. The control arms are the brackets that go out to the wheel - above and below the spindle - holds all of the wheel assembly - pivoits on a shaft to let the wheel go up & down over bumps. The transverse link holds things togetherfrom side to side.- Jeff Link to comment https://www.classiczcars.com/forums/topic/6158-what-to-save/?&page=2#findComment-37620 Share on other sites More sharing options...
May 16, 200321 yr comment_37622 Actually, I believe that the FSM uses the term "Transverse links" for what we in the US call "Lower control arms". At least in the 1971 and 1973 FSM's. Link to comment https://www.classiczcars.com/forums/topic/6158-what-to-save/?&page=2#findComment-37622 Share on other sites More sharing options...
May 16, 200321 yr comment_37626 Hmmm....so in this picture, I see a1) strut and rear drum brake assembly2) a halfshaft/driveshfat3) spindle pin4) transverse linkhttp://www.classiczcars.com/forums/attachment.php?s=&postid=37792what do others see? :classic: which or what is the control arm if it is not the transverse link?I dont know what Australian or American terminolgy is, I just use the names in my Haynes manual which could be half my problem. Link to comment https://www.classiczcars.com/forums/topic/6158-what-to-save/?&page=2#findComment-37626 Share on other sites More sharing options...
May 16, 200321 yr comment_37645 Unsafe / nonoperative parking brake...??- Jeff Link to comment https://www.classiczcars.com/forums/topic/6158-what-to-save/?&page=2#findComment-37645 Share on other sites More sharing options...
May 16, 200321 yr comment_37648 Well if you want to play that game you could also point out the nuts on the spindle pin and lock bolt are missing and "unsafe" too... What would really be unsafe about driving my car now is that the rear struts, diff and driveshafts are all on the floor in my garage......including the handbrake cables :cross-eye Anyhow.... So is what im calling a transverse link what you call a control arm? Link to comment https://www.classiczcars.com/forums/topic/6158-what-to-save/?&page=2#findComment-37648 Share on other sites More sharing options...
May 16, 200321 yr comment_37651 DOn't have my manuals with me here, but I believe that Haynes uses the same (or very similar) terminology as the FSM.YES, What you and Haynes, & FSM (and probably George ( screen name = 240Z) are calling a Transverse Link is what I and most US folk call a Lower control arm. Similar to a Lower Wishbone on an F1 or Champ Car. Link to comment https://www.classiczcars.com/forums/topic/6158-what-to-save/?&page=2#findComment-37651 Share on other sites More sharing options...
May 16, 200321 yr comment_37662 Thanks for clearing that up, I think must guys over here call it that too....its just me and Mr. Haynes Link to comment https://www.classiczcars.com/forums/topic/6158-what-to-save/?&page=2#findComment-37662 Share on other sites More sharing options...
