Recently Browsing 0
Hey I just joined here! IV been planning this build for about 5 years now and finally been actively working on it in my free time here and there for about a year and a half! This is the first engine swap I have ever attempted and it now runs and drives! Next step is an exhaust system and then getting it on a Dyno for the standalone ecu to be fully tuned! Please ask any questions and im very open to suggestions as to what to do next, because it still is a bone stock 280z chassis... And that's not good due to the 400hp minimum I plan to make at the wheels. The engine is a 1jzgte out of a jzx90 the Toyota mark II , cresta , or the mark X as it's also refered to , basically it's the JDM version of the Toyota Cressida that was sent to the states that I believe used a 5mge engine . Here is a list of all that I can think of that is done to the 1jz that is not stock!
Link g4+ monsoon stand alone ECU,Panic Wire harness,10lb flywheel, 264 cam shafts, Head ported (intake side only), Adjustable cam gears,
Eclutchmasters 6 puck unsprung clutch and pressure plate (stage 4)Drift Motion turbo kit Billet 6262 turbo (Garrett internals), manifold, wastegate tial replica, and 3" downpipe, Hks bov replica, Aeromotive fuel pressure regulator, 440cc injectors,Bosch 044 fuel pump, Arp head studs, rear sump oil pan conversion, Aem wideband
Short throw shifter, a/c and p/s delete (shortened serpentine belt and new ribbed pulley on tensioner),vvti coils wasted spark setup, CX racing intercooler
Edited by 1jzs30
Add picture
https://www.classiczcars.com/forums/topic/61591-1977-280z-1jzgte-swap/Share on other sites
