February 17, 20196 yr comment_568554 1 hour ago, siteunseen said: There's some Ford inner fender that's close, a littile too large but they'll work. Ebay has 50 for about $10 or so? @gwri8 @SteveJ turned me onto them. https://www.ebay.com/itm/50-FORD-FENDER-SHIELD-PUSH-TYPE-RETAINERS-OEM-387843-S/253285631459?epid=1189303991&hash=item3af90005e3:g:zaEAAMXQlrxRa9Hi:rk:4:pf:0 Link to comment https://www.classiczcars.com/forums/topic/61612-internal-rivets/?&page=2#findComment-568554 Share on other sites More sharing options...
February 17, 20196 yr comment_568556 I just picked these up but from a source in USA. Looks like they will fit20 x For BMW E36 E39 5mm Hole Expanding Rivet Convertible Top, Fender Liner Clip https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F232864207393 Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/61612-internal-rivets/?&page=2#findComment-568556 Share on other sites More sharing options...
February 17, 20196 yr comment_568558 16 hours ago, ryanotown22 said: I just picked these up but from a source in USA. Looks like they will fit 20 x For BMW E36 E39 5mm Hole Expanding Rivet Convertible Top, Fender Liner Clip https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F232864207393 Sent from my iPhone using Classic Zcar Club mobile I measured what I believe to be a genuine Nissan panel rivet to compare to the measurements of the BMW part. The BMW part seems to be a little smaller. Those rivets may have issues with staying firmly in the anchor points. The measurements for the Nissan part numbers are in blue. Edited February 17, 20196 yr by SteveJ Revised the measurements on the rivet. Link to comment https://www.classiczcars.com/forums/topic/61612-internal-rivets/?&page=2#findComment-568558 Share on other sites More sharing options...
February 17, 20196 yr comment_568561 Wow thanks for doing those measurements Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/61612-internal-rivets/?&page=2#findComment-568561 Share on other sites More sharing options...
February 17, 20196 yr comment_568562 So this got me looking on ebay. I found some panel rivet kits that have rivets in a similar size to the Z rivets. https://www.ebay.com/itm/690Pcs-Car-Auto-Push-Pin-Rivet-Trim-Fastener-Clip-Panel-Body-Interior-Assortment/254096165616?hash=item3b294fcaf0:g:bREAAOSwh99cSstW:rk:2:pf:0 https://www.ebay.com/itm/690pcs-Car-Automotive-Push-Pins-Rivet-Trim-Clip-Panel-Body-Kits-Assortment/173657019916?epid=21026357388&hash=item286ec3d60c:g:0AAAAOSw6jJb-LiG:rk:3:pf:0 It looks like the Nissan part is designed for a 5mm hole, while the Ford (and many others on the market) appear to be designed for a 1/4 inch hole. And to make a correction, it looks like the BMW rivet is likely the correct width. Depth may still be an issue. Let us know if they work. Link to comment https://www.classiczcars.com/forums/topic/61612-internal-rivets/?&page=2#findComment-568562 Share on other sites More sharing options...
February 17, 20196 yr comment_568563 And the genuine article from Courtesy Nissan: https://www.courtesyparts.com/oem-parts/nissan-rivet-plastic-black-90909e4100 And Nissan Parts Deal: https://www.nissanpartsdeal.com/parts/nissan-rivet-plastic~90909-e4100.html Tasca: https://www.tascaparts.com/oem-parts/nissan-rivet-plastic-black-90909e4100 Edited February 17, 20196 yr by SteveJ Link to comment https://www.classiczcars.com/forums/topic/61612-internal-rivets/?&page=2#findComment-568563 Share on other sites More sharing options...
February 17, 20196 yr comment_568565 Harbor Freight has a 90 rivet set that contains 50 5mm rivets for a reasonable price. https://www.harborfreight.com/90-piece-pom-rivet-assortment-67611.html Dennis Link to comment https://www.classiczcars.com/forums/topic/61612-internal-rivets/?&page=2#findComment-568565 Share on other sites More sharing options...
February 17, 20196 yr comment_568630 19 hours ago, psdenno said: Harbor Freight has a 90 rivet set that contains 50 5mm rivets for a reasonable price. https://www.harborfreight.com/90-piece-pom-rivet-assortment-67611.html Dennis Harbor Freight in Palm Springs? Probably one in Mar-a Lago for the "Beast" when it needs some Schina valve caps. Edited February 17, 20196 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/61612-internal-rivets/?&page=2#findComment-568630 Share on other sites More sharing options...
February 17, 20196 yr comment_568634 That was funny in my head a minute ago but not so much now. I apologize Dennis. It's been raining all day here and I'm a little stir crazy from being inside. Sorry! Harbor Freight is everywhere thank goodness. Link to comment https://www.classiczcars.com/forums/topic/61612-internal-rivets/?&page=2#findComment-568634 Share on other sites More sharing options...
February 17, 20196 yr comment_568639 Gave up on these rivets a long time ago. Now I install steel 10-24 riv-nuts and black oxide truss head machine screws. https://www.mcmaster.com/94779A620 Never lose the pins, panels are held down tight. Works great for black interiors, I guess you'd be painting heads for other color interiors. Black on white or blue or tan would look cool though wouldn't it? Yes you have to drill out each of the 5mm holes to whatever size the riv nuts need but once you do it you'll never baulk when you have to remove a panel to do any modifications (which we never do, right?) Link to comment https://www.classiczcars.com/forums/topic/61612-internal-rivets/?&page=2#findComment-568639 Share on other sites More sharing options...
February 18, 20196 yr comment_568663 3 hours ago, siteunseen said: That was funny in my head a minute ago but not so much now. I apologize Dennis. It's been raining all day here and I'm a little stir crazy from being inside. Sorry! Harbor Freight is everywhere thank goodness. No apology needed. And you're correct. No harbor Freight in Palm Springs. I have to leave town to shop at one. I can relate to going stir crazy on a rainy day. The rain here last Thursday wiped out the only three roads leading out of town to the interstate. Nine inches of rain locally. Stay dry! Dennis Link to comment https://www.classiczcars.com/forums/topic/61612-internal-rivets/?&page=2#findComment-568663 Share on other sites More sharing options...
February 24, 20196 yr comment_569204 So my review of the bmw rivets..I put in the rear quarter plastic panels only so far. They hold the panels tight and I believe they will work but I wish the head area was a larger circle the rivets I have are 10mm circles head and I think the Nissan ones are 13mm based on the specs a few posts up. I am going to use them for now and see if they work on all the panels. I have a 280z not sure if that matters though. I will update this when I put more panels in.Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/61612-internal-rivets/?&page=2#findComment-569204 Share on other sites More sharing options...
