3 minutes ago, Mark Maras said:
 @PatconWhat years will work and which three are we looking for?
I don't really know which years interchange. I believe the fronts and backs are the same. @zKars I need the lower hinges. The ones with the springs. I believe the existing ones have the scissor bars but I believe the front right one is a newer style. I will try to get some pictures up.
  Pulled some part #s from carpartsmanual.com 1968-1973.
 rear upper rh 82400-21002
 rear lower rh 80420-21004
 spring            80422-73001
 rear upper lh 82401-21002
 rear lower lh 80421-21004
 Check out sgnauto.com. I ran the first two #s. They list the upper hinge for $27.00. Lower hinge is $97.00. I didn't go farther than that. The business appears to be wholesale only. Not an insurmountable hurdle, IMO. Haven't found any on Craigslist yet.
 spring            80422-73001
Thanks for the effort. I will follow up on it
9 hours ago, 240260280 said:
Are you in a rush?  I think there are lots of 510 parts in our Z barn.
The car is going to paint jail in about a week. I need to source some for the painter. Not really a rush but I will need them sooner than later. We spent all day yesterday after church stripping the car. That's when I noticed them for the first time
7 hours ago, 240260280 said:
Rats. Too short for me to look. Sorry ?
When would you be able to check?
Here are pics of what I have
Drivers door - missing the spring - probably salvageable
Drivers side passenger door - missing the spring and the pivot pin is broken. Might be salvageable
Right side rear door - missing the spring and mangled. Might be hard to salvage this one
Front right door - we painted this one. It's complete and seems to function properly
 spring            80422-73001
How did you run parts on their site? How would you go about sourcing parts from this wholesaler?
I checked at Courtesy and all of these numbers are NLA. I wonder if sgnauto just has some NLA numbers in their database
Any ideas on how to match up the spring? I can probably get the existing spring out but I wouldn't really know how to go about sourcing them.
