Installing 2 post lift
z8987
13 minutes ago, 240260280 said:
Would you stand under your car knowing the lift was made in a country where it is ok to:
lie
falsify certification documents
not vet supply chain
ship parts that are not manufactured correctly?
I would build some trusses to put under your car just in case.
As I understand it the Rotary are good lifts, it’s just the revolution that’s bad , is that corrrect?
1 hour ago, Marty Rogan said:
That is a very nice shop!  What did you use for insulating the roof?
What kind of heat do you have?
Insulation and heating are next on my list for my shop once the weather starts getting better around here.
Why did you opt for the 2 post vs a 4 post lift?
I had the insulation installed when it was made. I have a kerosine heater. I'd like to find some type of electric heat so I don't have to keep the doors open. Any ideas.
I chose 2 post over 4 because everybody that works around lifts day to day recommend them.  The 4 posts seem to be in the way a lot.
  • Who's Online   2 Members, 0 Anonymous, 680 Guests (See full list)
