I have decided to rewire my aging wiring loom and upgrade it to execute all the little upgrades I have in mind. I am by no means an electrical master, but I know the importance even our 70's cars need. My plans for my '74 260z is to wire tuck, hide the wires in the engine bay to be nearly nonextant, and to also include motor sport techniques to make quality upgrades. All wires will be replaced by Tefzel wire and Raychem heat shrink. the point is to make a bulletproof wire loom and to have fun working on this project and making it special. Now for everyone's benefit i will be updating this with all the stock wiring specs as they are on my car with what ever has happened to this car in the past 45 years. I will come up with a Key to understand the small database i am trying to start. the end goal is to help others in their wiring  projects.
the github link: https://github.com/youztheclue/S30-Spec.git
KEY:
      System name: Subsection
      Detailed description to-from/Route
      #gauge(American), Stock color, My new color for reference
      Stock length, New route with reasons for change, length of heat shrink for specific subsection
      Expected electrical load, name of oe connector/number of wires, new connector style and size
Hopefully I can create something useful here: and I encourage others to comment, tips, hints, hidden secrets and their own data and I will add it to my data set.
Update: I now have the entire front half from the firewall to bumper measured and mapped out. Will be updating soon.
Lights: Exterior
Headlights
Turn Signals
Taillights
Brake Lights
Lights: Interior
Dash
Map
Wipers:
Motor
Fluid Pump
Engine: Starting
Fuel Pump
Ignition
Coil
Electric Choke
Engine: Constant for running
Electric Fan(s)
Alternator
Fuel Injection
Ignition
Dash/Instruments:
Gauges
Switches
Luxury:
Heater/Fan
A/C
Radio
Power Windows
Power Door Locks
Edited by youztheclue
  • 1 month later...
Sure um I'm going to look into doing that. I've visited GitHub once or twice but never really used it. i linked the git hub after the intro.
new link
im striping my engine bay now and also trying to learn GitHub which is no easy task. tomorrow i will be stripping back the wiring loom to get and accurate readings.
  • 1 month later...
Update on the wiring. I have the whole front engine bay harness unwrapped. It's undone all the way to the firewall. I'm going to remove and add a couple wires, shorten some, replace others. A nice rewrap and the electrical will be good while I create the really nice loom on the bench.
  • 2 months later...
I just put my engine back together and started the engine up. Also all the electrical components are working. So now that I know everything I have is working good I will start updating this with all the notes that I have. Also I will do the same on GitHub.
