Please forgive me if my terminology is a bit off, I'm posting this as I uncover this problem, and my FSM was foolishly wiped with the rest of my computers memory.
I took my Z on a drive today, but didn't get far until I heard some evil coming from the rear end. It turns out that my passenger side half shaft (I can never remember if they are technically CV or half shafts) has dislodged itself quite a bit from where it seats in to the differential.
I pulled it out. There appears to be no damage, but the question remains... How did this happen? Is there supposed to be some sort of circlip at the end of the spline assembly, in the notched groove?
I've never removed the spline from the differential, however about a year or so ago I replaced the half shafts with some that had less miles on them. I thought the original ones were clicking, but it turns out that noise was from the rear brake pad pins not being installed properly. I still have my original half shafts.
Thanks in advance for any input.
The car is a stock 1980 ZX. R180.
Sent from my N9130 using Tapatalk
11 minutes ago, Mark Maras said:
Does the clicking frequency increase with vehicle speed? Does the noise go away if you turn going 10-15 MPH or does the noise change when you tap the brakes? (Thanks Charles)
The noise goes away after approximately 10 MPH(15MPH at the most).  it doesn't go away when I turn, and seems to be concurrent with wheel speed.  If i brake it goes away, or at the very least, gets quieter.
Edit: I'll have to drive it again to verify for sure that the noise does not go away turning beyond 15MPH.  Thinking back, I cannot be 100% sure that when I experience the noise, that I have turned the car at or beyond 15MPH.  I just know that if i turn into my driveway from my street and it's making the noise, I will still be making the noise.  But in reality, that's probably about 2-5 MPH if even that.  So I'll test again and report back.
Edited by Reptoid Overlords
The noise is likely coming from the worn u joints on the shafts, I don't think you have replaced them.  You can change them yourself for around $20 (Neapco) each or any driveline shop Seattle can do it at a reasonable price if you take them just the shafts.  (the permanently lubed ones are stronger than the greaseable  type.   Drivelines NW is a good choice for parts or the work in your area.
Edited by S30Driver
spelling
I've gotten Spicer U-joints from Drivelines NW in the past.  Thanks for the input.  Not really having dealt with halfshaft rear ends, i wasn't sure what to look for as far as signs of failure.  I've only experienced the typical clicking from FWD cars when turning.
I noticed the other day when I removed the old differential that if you spin one side, the other side spins a lot slower than the side you are spinning by hand. Sometimes, it doesn't even spin at all. The spare differential spins the same speed and doesn't stop until you stop spinning it. Also it seems a bit "tighter" than the old one. I haven't got my halfshafts back from the shop yet, but I'm guessing my old differential has some problems. Also, the other side spline came out when I removed the halfshaft. So now both sides have no circlips. 83ddf6d24833cc9c8bf0cd484b3469f8.jpg21fe4cbdf311170f54b29c26f2deb2f0.jpg
I got the halfshafts back from NW driveline.  They did great work.  Even painted them.  I've put everything back together and went on a test run with some mixed city/freeway driving.  Don't hear any clicks or any other abnormal noises.  The diff whined a bit at first but shut up after a bit of driving.  I guess I can move on to other things now.  Thanks to all who pointed me in the right direction.
Good job.   A great place for testing drive line noise, u joints, is a underground or enclosed public parking garage.  The enclosed space and tight turns up & down the ramps amplify the noise, make it easier to tell left side or right etc.
I pulled the cover of the back of the original differential. I don't see any circlips, or evidence that they grenaded inside. Is it factory RTV in lieu of a gasket on the rear cover? It would make sense, I know Toyota used their FPIG and Honda had its Hondaseal or whatever. 960e34b4707402f088d36ea561083d5d.jpg7abdbde3390e97a0fada5cfb564a5ff6.jpgfc43e048446e5218d634248ebdf816af.jpg
Thanks.  It's possible then that someone had it apart at some point in it's life, and did not install circlips upon re-assembly, as there was no gasket, just RTV between the diff case and the rear cover.
That's very possible considering how difficult those ring clips are to install.
Recently Browsing 0
