Posted February 26, 20196 yr comment_569440 Similar design to some SU tools. Link to comment https://www.classiczcars.com/forums/topic/61675-fyi-porsche-float-heightfuel-height-tool/ Share on other sites More sharing options...
February 26, 20196 yr comment_569453 Very cool, Phil! My buddy, Randalla, created the Float Sync tool that is used with SU carbs that looks similar to this. He is now looking to make more of them for sale to the Z crowd! Link to comment https://www.classiczcars.com/forums/topic/61675-fyi-porsche-float-heightfuel-height-tool/#findComment-569453 Share on other sites More sharing options...
February 27, 20196 yr comment_569557 Thanks for the mention Duffman. The tool I created sold out quickly about a year ago and I had not planned to produce anymore but recently decided to produce additional units due to the demand and emails I have been getting. I'm still a month away from having quantities for sale but here are a few pictures. Link to comment https://www.classiczcars.com/forums/topic/61675-fyi-porsche-float-heightfuel-height-tool/#findComment-569557 Share on other sites More sharing options...
February 27, 20196 yr comment_569594 Here's a few pictures of Float-Sync in use. Link to comment https://www.classiczcars.com/forums/topic/61675-fyi-porsche-float-heightfuel-height-tool/#findComment-569594 Share on other sites More sharing options...
February 28, 20196 yr comment_569628 I have been watching these for sometime now. Are they designed to stay on full time? Photos don’t show fuel in the tube? I can’t tell if if they are calibrated? 72 body and block, everything else 71, Tokico springs, Illumina, R180 CLSD, 83 close ratio, 3.90 gears, Ztherapy SUs, BRE 15X7 Libre wheels and BRE front spoiler. Link to comment https://www.classiczcars.com/forums/topic/61675-fyi-porsche-float-heightfuel-height-tool/#findComment-569628 Share on other sites More sharing options...
February 28, 20196 yr comment_569633 7tooZ, the Float Sync can be left on for a test drive, with the air filter removed, but they are not designed to be left on. The sample pics that Randalla posted do not show any actual fuel in the tubes. They are not specifically marked, but 14mm above the block is 21 mm down from the edge of the fuel bowl; the desired level. I actually scored, very lightly, the desired mark to see where the fuel needs to be. I would highly recommend these! Link to comment https://www.classiczcars.com/forums/topic/61675-fyi-porsche-float-heightfuel-height-tool/#findComment-569633 Share on other sites More sharing options...
February 28, 20196 yr comment_569674 I intentionally didn't scribe marks on the site glass, but rather included instructions to set floats at the proper level, as Duffman suggests. Some owners prefer their floats set differently. One nice thing about these tools is that you can visually check the fuel level throughout the entire rpm range to to assure you never run the float bowls dry even under full acceleration for an extended period of time. Two tools are included in each set to simultaneously check each carburetor at the same time. It's critical to proper tuning that float levels are as close as possible. If they're not, the number of turns out on the mixture nuts will differ in order to compensate. Link to comment https://www.classiczcars.com/forums/topic/61675-fyi-porsche-float-heightfuel-height-tool/#findComment-569674 Share on other sites More sharing options...
June 11, 20195 yr comment_577404 I want a set of those! I bought a pair of the plastic hoses sold by Ztherapy and have been using them but these ones seem to provide more accuracy! Do you ship to Miami, FL? Link to comment https://www.classiczcars.com/forums/topic/61675-fyi-porsche-float-heightfuel-height-tool/#findComment-577404 Share on other sites More sharing options...
June 11, 20195 yr comment_577415 Found the Float Sync's here; http://www.2040-parts.com/datsun-240z-su-carburetor-float-sync-tool-i1994669/ Link to comment https://www.classiczcars.com/forums/topic/61675-fyi-porsche-float-heightfuel-height-tool/#findComment-577415 Share on other sites More sharing options...
June 11, 20195 yr comment_577431 I took the advice and bought some banjo fittings and used 5mm clear pipe ... Link to comment https://www.classiczcars.com/forums/topic/61675-fyi-porsche-float-heightfuel-height-tool/#findComment-577431 Share on other sites More sharing options...
June 11, 20195 yr comment_577432 On 6/11/2019 at 4:35 PM, jalexquijano said: I want a set of those! I bought a pair of the plastic hoses sold by Ztherapy and have been using them but these ones seem to provide more accuracy! Do you ship to Miami, FL? Put me on your list for a set too. Thanks, Marty Link to comment https://www.classiczcars.com/forums/topic/61675-fyi-porsche-float-heightfuel-height-tool/#findComment-577432 Share on other sites More sharing options...
June 11, 20195 yr comment_577437 I have the Float Sync, and think it works quite well. The way I use it is to lay a 14mm nut on the edge as shown and that gives me a great level indicator. Link to comment https://www.classiczcars.com/forums/topic/61675-fyi-porsche-float-heightfuel-height-tool/#findComment-577437 Share on other sites More sharing options...
