Hello and thank you for looking at my ad!
Undergoing an engine swap I no longer need my 3 screw SU’s - These will be cleaned up before sending.
You get
(2) SU’s
Throttle Linkage
balance tube
intake manifold e46 (I think)
pricing is $450 for it all + Shipping. These carbs came off my RUNNING Z before I decided on my LS Swap.
___________
Stock Front LCA’s with Tie Rods
 - Come with energy suspension Bushings already installed
 - Repainted with Chasis paint and then baked on.
Also comes with energy suspension tie rod bushings. I broke another set when I used both so go with stock rubber in front and poly in the rear.
$200 + S/h
_____________
Stock Rear LCA’s
 - Come with energy suspension poly bushings
Comes with High grade bolts for spindles
$200+s/h
I take -
Zelle , PayPal or cash :)
Please reach out with any questions!
- Don
inalso have a Air Box OR K&N filters if you need these as well.
@DonH  we have a new classifieds system here:  https://www.classiczcars.com/classifieds
I recommend placing separate ads for each item if you can..
Mike
