Posted February 26, 20196 yr comment_569508 Having trouble locating Redline MT90 for my 83ZX 5 speed. What else might work? Link to comment https://www.classiczcars.com/forums/topic/61681-hard-to-find-redline-mt90/ Share on other sites More sharing options...
February 26, 20196 yr comment_569510 Try Amazon? https://smile.amazon.com/Red-Line-50304-Transmission-Transaxle/dp/B000CPCBEQ/ref=sr_1_1?keywords=redline+mt90&qid=1551223687&s=gateway&sr=8-1 Link to comment https://www.classiczcars.com/forums/topic/61681-hard-to-find-redline-mt90/#findComment-569510 Share on other sites More sharing options...
February 27, 20196 yr comment_569517 Pennzoil Synchromesh is popular. Chickenman and others around the internet say that Friction-Modified Synchromesh is good also. Link to comment https://www.classiczcars.com/forums/topic/61681-hard-to-find-redline-mt90/#findComment-569517 Share on other sites More sharing options...
February 27, 20196 yr comment_569518 The NAPA auto parts store nearby my house in downtown Everett (of all places) stocks Redline MT90. They don't advertise it. Perhaps one in your neighborhood does the same thing. Sent from my N9130 using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/61681-hard-to-find-redline-mt90/#findComment-569518 Share on other sites More sharing options...
February 27, 20196 yr comment_569522 My testimonial-----I still stand by it. "Had a notchiness in 1 to 2 shifts on my low mileage trans. Decided to try Royal Purple as that was all I could find as "upgrade" locally. No change. Changed to Redline after ordering it from online as it was the one that was supposedly much better. No change. Enter A/C Delco Friction Modified-----kaaaazzing-----we have a winner!! ~$32.00 for three quarts----some of the best "bang for the buck" money I've spent on the Z. Notchiness is gone --all shifts are much smoother. Spend the money on it and be done with it for years to come-----enjoy the benefit with every shift!!! HIGHLY RECOMMENDED AAAA++++" Link to comment https://www.classiczcars.com/forums/topic/61681-hard-to-find-redline-mt90/#findComment-569522 Share on other sites More sharing options...
February 27, 20196 yr comment_569523 One key is to know what you're trying to fix. High RPM synchro problems and notchiness are different things. Many people use plain old 75-90w and do fine, while saving some money. If you want to get fancy use Swepco 201 and ATF at a 3:1 ratio. I use it on my old worn ZX 5 speed and it fixed all of my problems. That's a JMortensen suggestion, except he mixes at 1:1 I think. Link to comment https://www.classiczcars.com/forums/topic/61681-hard-to-find-redline-mt90/#findComment-569523 Share on other sites More sharing options...
February 27, 20196 yr comment_569525 I bought some recently from Amazon. I think it was offered for 2 day delivery. It was a choice between that and Zup AC Delco F/Mod If I had had that endorsement first, I would have gone that route Link to comment https://www.classiczcars.com/forums/topic/61681-hard-to-find-redline-mt90/#findComment-569525 Share on other sites More sharing options...
February 27, 20196 yr Author comment_569528 Sorry I should have been more specific about what I am doing. I Have the car on jack stands to replace the speedometer drive gear from a blue (3.70 gear) to the white for a 3.90 gear set. I drained the gear lube to check for any signs that something is wrong. I purchased this transmission 1000 miles ago. I found no signs of unusual wear in the oil or the magnet. I have been using MT90 in my transmissions for 15 yrs. and was surprised when I couldn’t find any on the self atOriellys, AutoZone or NAPA. Amazon has it but have to wait. Thought I would see if others have better ideas. Just need a good gear oil. $32 doesn’t seem expensive. @Zup always has good advice. Anybody else want to weight in? 72 body and block, everything else 71, Tokico springs, Illumina, R180 CLSD, 83 close ratio, 3.90 gears, Ztherapy SUs, BRE 15X7 Libre wheels and BRE front spoiler. Link to comment https://www.classiczcars.com/forums/topic/61681-hard-to-find-redline-mt90/#findComment-569528 Share on other sites More sharing options...
February 27, 20196 yr comment_569533 Thanks 7tooZ. It isn't my idea, only my observed results and belief. Credit goes to Chickenman, as he described it at length in this thread from 2015. He always has good advice---he was a Nissan certified tech for years I believe. Link to comment https://www.classiczcars.com/forums/topic/61681-hard-to-find-redline-mt90/#findComment-569533 Share on other sites More sharing options...
February 27, 20196 yr comment_569534 I'm using Synchromesh in a Ford transmission and it's good stuff. I've been thinking about using the Friction-modified for a little more. It's a notoriously notchy transmission. The Ford spec. Mercon V was terrible compared to the Synchromesh. Link to comment https://www.classiczcars.com/forums/topic/61681-hard-to-find-redline-mt90/#findComment-569534 Share on other sites More sharing options...
February 27, 20196 yr Author comment_569541 My testimonial-----I still stand by it. "Had a notchiness in 1 to 2 shifts on my low mileage trans. Decided to try Royal Purple as that was all I could find as "upgrade" locally. No change. Changed to Redline after ordering it from online as it was the one that was supposedly much better. No change. Enter A/C Delco Friction Modified-----kaaaazzing-----we have a winner!! ~$32.00 for three quarts----some of the best "bang for the buck" money I've spent on the Z. Notchiness is gone --all shifts are much smoother. Spend the money on it and be done with it for years to come-----enjoy the benefit with every shift!!! HIGHLY RECOMMENDED AAAA++++" Is this what you are recommending 72 body and block, everything else 71, Tokico springs, Illumina, R180 CLSD, 83 close ratio, 3.90 gears, Ztherapy SUs, BRE 15X7 Libre wheels and BRE front spoiler. Link to comment https://www.classiczcars.com/forums/topic/61681-hard-to-find-redline-mt90/#findComment-569541 Share on other sites More sharing options...
February 27, 20196 yr comment_569542 Yessiree! I mean--- whoa-wait a minute---that isn't Friction Modified! You ought to be able to get A/C Delco Friction Modified transmission fluid from any GM dealer. Edited February 27, 20196 yr by Zup Link to comment https://www.classiczcars.com/forums/topic/61681-hard-to-find-redline-mt90/#findComment-569542 Share on other sites More sharing options...
