Posted March 7, 20196 yr comment_570331 I have 1971 240Z (7/71) and the shifter boot (inner and outer) is completely missing. I see some videos that show the boot ring (retainer), but I'm thinking there may not be a ring for the Series 1. Am I correct that I only use clips to secure the outer boot cover? Any help is appreciated. Edited March 7, 20196 yr by wadelester more clear Link to comment https://www.classiczcars.com/forums/topic/61762-1971-240z-shifter-boot-clips-or-ring/ Share on other sites More sharing options...
March 7, 20196 yr comment_570333 That is correct. Do you have them. I probably have some extras. The innerboot is not screwed to console until the series II console. Post a picture of the console to get confirmation 72 body and block, everything else 71, Tokico springs, Illumina, R180 CLSD, 83 close ratio, 3.90 gears, Ztherapy SUs, BRE 15X7 Libre wheels and BRE front spoiler. Link to comment https://www.classiczcars.com/forums/topic/61762-1971-240z-shifter-boot-clips-or-ring/#findComment-570333 Share on other sites More sharing options...
March 8, 20196 yr Author comment_570334 The pic may not help as I don't have the center console removed yet. Interestingly, I thing the original boot is still on the car, but it's in bad shape. Link to comment https://www.classiczcars.com/forums/topic/61762-1971-240z-shifter-boot-clips-or-ring/#findComment-570334 Share on other sites More sharing options...
March 8, 20196 yr Author comment_570336 Is that white material original? I doesn't look like it. It's a tough plastic material I think they added instead of an inner and outer boot. To make things right, I believe I'll need the inner boot, outer boot, six clips, and a new leather boot. Are the clips used to secure just the rubber outer boot, or does it secure the rubber and leather to the frame. Any pics you may have are appreciated. Link to comment https://www.classiczcars.com/forums/topic/61762-1971-240z-shifter-boot-clips-or-ring/#findComment-570336 Share on other sites More sharing options...
March 8, 20196 yr comment_570341 1 hour ago, wadelester said: Is that white material original? I doesn't look like it. It's a tough plastic material I think they added instead of an inner and outer boot. To make things right, I believe I'll need the inner boot, outer boot, six clips, and a new leather boot. Are the clips used to secure just the rubber outer boot, or does it secure the rubber and leather to the frame. Any pics you may have are appreciated. The "leather" boot attached to the shift lever attaches to the opening in the center console with clips. Lacking those clips, you can use small paper clips like these: https://tinyurl.com/yxcl27rc They're hidden, so it won't matter to anyone but you. When you upgrade to a 5 speed, the later style inner rubber shifter boot is bolted to the floor with a metal frame. Dennis Link to comment https://www.classiczcars.com/forums/topic/61762-1971-240z-shifter-boot-clips-or-ring/#findComment-570341 Share on other sites More sharing options...
March 8, 20196 yr comment_570350 The pic may not help as I don't have the center console removed yet. Interestingly, I thing the original boot is still on the car, but it's in bad shape. I have never seen material that looks Like that on the many early cars I have worked I on. My first 71 the outer shift boot was vinyl and did have a off white netting attached on the back side. You can purchase both vinyl or leather reproductions. Attaching it is pretty straight forward. 72 body and block, everything else 71, Tokico springs, Illumina, R180 CLSD, 83 close ratio, 3.90 gears, Ztherapy SUs, BRE 15X7 Libre wheels and BRE front spoiler. Link to comment https://www.classiczcars.com/forums/topic/61762-1971-240z-shifter-boot-clips-or-ring/#findComment-570350 Share on other sites More sharing options...
March 8, 20196 yr comment_570398 Here's a couple of old threads that might be useful in some way or another with your console restore. Link to comment https://www.classiczcars.com/forums/topic/61762-1971-240z-shifter-boot-clips-or-ring/#findComment-570398 Share on other sites More sharing options...
August 13, 20204 yr comment_604161 I recently purchased a 240 10/70 build date. I wanted to replace the shifter bushings and boots. Ordered parts prior to opening it up, (mistake I know). What I found is that nothing I ordered fits... I’m a newby but looking for advice on where to order the correct parts and how to search for them. Thanks Link to comment https://www.classiczcars.com/forums/topic/61762-1971-240z-shifter-boot-clips-or-ring/#findComment-604161 Share on other sites More sharing options...
August 13, 20204 yr comment_604162 Here's what I've used on my 240 and 280. http://www.atlanticz.ca/zclub/techtips/shifterbushing/index.html Link to comment https://www.classiczcars.com/forums/topic/61762-1971-240z-shifter-boot-clips-or-ring/#findComment-604162 Share on other sites More sharing options...
August 13, 20204 yr comment_604164 Here are the bushings you need for the “A” type transmission that you have. Search for Datsun 510, there more people supplying them for their “A” type trans that is the same (shifter mount at least) as the early Z trans. Found these on ebay. This is the shift boot you need, that fits the trans tunnel. It has a groove that fits on the trans tunnel cut out. Edited August 13, 20204 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/61762-1971-240z-shifter-boot-clips-or-ring/#findComment-604164 Share on other sites More sharing options...
August 14, 20204 yr comment_604167 Thanks for the prompt responses! @siteunseen, that looks like a different set up than the “dog leg” shifter that’s in my car. The pin in mine is smaller and doesn’t seem to have enough room for bushings at all. Thinking I’ve got an older transmission but I am new to this scene and have a lot to learn. @zKars as it turns out my shifter boot is in really good condition, it is just like the one in the pics you sent. Does the bushing in the top pic belong on the bottom of the shifter? Mine has a hard plastic bushing just above the lock nut. My nomenclature is terrible, I’ll get the manual so I can better describe what I’m talking about. I took it all apart to install the parts , got disappointed when NOTHING matched and put it back together so I can’t get any better pics at the moment. Link to comment https://www.classiczcars.com/forums/topic/61762-1971-240z-shifter-boot-clips-or-ring/#findComment-604167 Share on other sites More sharing options...
August 14, 20204 yr comment_604172 You can get the bushings a Z car Source https://zcarsource.com/shifter-bushing-240z-70-71-new do not buy the metal ones on EBay you will hate the feeling . Be careful when you tighten the nut the chrome on on the shifter will mar easily.. the lever should be straight not dog legged. Let me know if you need photos Link to comment https://www.classiczcars.com/forums/topic/61762-1971-240z-shifter-boot-clips-or-ring/#findComment-604172 Share on other sites More sharing options...
