March 17, 20196 yr Author comment_571124 Pulled the rear brake proportioning valve off this evening and took it apart. The lower seal was full of some kind of sandy material. Does anyone have one of these Sumitomo valves they would be willing to sell? I am in the process of going through each component of the brake system. "One bite at a time". JLP Link to comment https://www.classiczcars.com/forums/topic/61778-brake-problems-still/?&page=3#findComment-571124 Share on other sites More sharing options...
March 17, 20196 yr comment_571130 I might have a spare. I would need to look around some Link to comment https://www.classiczcars.com/forums/topic/61778-brake-problems-still/?&page=3#findComment-571130 Share on other sites More sharing options...
March 17, 20196 yr comment_571144 Is the throw of the push rod from the pedal correct? Link to comment https://www.classiczcars.com/forums/topic/61778-brake-problems-still/?&page=3#findComment-571144 Share on other sites More sharing options...
March 18, 20196 yr comment_571228 On 3/17/2019 at 2:39 AM, JLPurcell said: Pulled the rear brake proportioning valve off this evening and took it apart. The lower seal was full of some kind of sandy material. Does anyone have one of these Sumitomo valves they would be willing to sell? I am in the process of going through each component of the brake system. "One bite at a time". JLP MSA sells a seal kit I have used successfully to refresh my valve. https://www.thezstore.com/page/TZS/PROD/24-5556 Apologies for the multiple posts. When I hit save, didn't work as I usually see. Sorry. Edited March 18, 20196 yr by jonathanrussell Link to comment https://www.classiczcars.com/forums/topic/61778-brake-problems-still/?&page=3#findComment-571228 Share on other sites More sharing options...
March 18, 20196 yr comment_571229 On 3/17/2019 at 2:39 AM, JLPurcell said: Pulled the rear brake proportioning valve off this evening and took it apart. The lower seal was full of some kind of sandy material. Does anyone have one of these Sumitomo valves they would be willing to sell? I am in the process of going through each component of the brake system. "One bite at a time". JLP MSA sells a seal kit I have used successfully to refresh my valve. https://www.thezstore.com/page/TZS/PROD/24-5556 Link to comment https://www.classiczcars.com/forums/topic/61778-brake-problems-still/?&page=3#findComment-571229 Share on other sites More sharing options...
March 18, 20196 yr comment_571230 On 3/17/2019 at 2:39 AM, JLPurcell said: Pulled the rear brake proportioning valve off this evening and took it apart. The lower seal was full of some kind of sandy material. Does anyone have one of these Sumitomo valves they would be willing to sell? I am in the process of going through each component of the brake system. "One bite at a time". JLP MSA sells a seal kit I have used successfully to refresh my valve. https://www.thezstore.com/page/TZS/PROD/24-5556 Link to comment https://www.classiczcars.com/forums/topic/61778-brake-problems-still/?&page=3#findComment-571230 Share on other sites More sharing options...
March 18, 20196 yr comment_571233 You bought 3 kits ? Link to comment https://www.classiczcars.com/forums/topic/61778-brake-problems-still/?&page=3#findComment-571233 Share on other sites More sharing options...
March 26, 20196 yr comment_571853 This probably wont be helpful at all but I had soft pedal. I bled the brakes numerous times and nothing helped. Finally I installed bleeder valves on the brakes and bled them again. That worked. Link to comment https://www.classiczcars.com/forums/topic/61778-brake-problems-still/?&page=3#findComment-571853 Share on other sites More sharing options...
March 26, 20196 yr comment_571854 Bleeder valves work good for me also. Definitely worth the money. Link to comment https://www.classiczcars.com/forums/topic/61778-brake-problems-still/?&page=3#findComment-571854 Share on other sites More sharing options...
April 5, 20196 yr Author comment_572680 I am happy to report that the brake problem is resolved. That is the good news. The bad news is that I have no idea what fixed it. I got so frustrated that I took each and every brake component apart and rebuilt it, flushed and blew out all of the lines and last night took it out for a spin and the brakes are working great. ? Link to comment https://www.classiczcars.com/forums/topic/61778-brake-problems-still/?&page=3#findComment-572680 Share on other sites More sharing options...
April 5, 20196 yr comment_572683 Glad you got it fixed! Since you mentioned the debris in the rear prop. valve, I am betting you ended up circulating some rust or dirt throughout the system when you bled it. Then the debris got stuck causing the issue. The brake components are somewhat precision pieces so it would not take much to create an issue. Taking everything a part, cleaning it, and rebuilding it along with the blow out of the lines ensures your system is clean. Link to comment https://www.classiczcars.com/forums/topic/61778-brake-problems-still/?&page=3#findComment-572683 Share on other sites More sharing options...
April 5, 20196 yr Author Popular Post comment_572686 My test drive last night, 10 minute test drive turned into a 1 hour cruse! I forget how much fun this car is to drive over the winter months. Link to comment https://www.classiczcars.com/forums/topic/61778-brake-problems-still/?&page=3#findComment-572686 Share on other sites More sharing options...
