Posted December 23, 200123 yr comment_1573 other than the riveted on plate, where else can you find the serial number on a 240Z ??? Link to comment https://www.classiczcars.com/forums/topic/618-serial-number-location/ Share on other sites More sharing options...
December 23, 200123 yr comment_1578 As far as I know.No were else unless its a North American car. Then it would be located on the top of the instrument panel cowl and is visible through the windshield.Also it should be on the the original log book. If you have the vehicle licence plate number the Local Driving Licence Vehicle Authorities could trace it for you.Good Luck. Link to comment https://www.classiczcars.com/forums/topic/618-serial-number-location/#findComment-1578 Share on other sites More sharing options...
December 23, 200123 yr Author comment_1579 it's an American car. I know it has the plate by the windshield as all US cars have. I was wondering if it was stamped anywhere on the chassis? Most US cars have "hidden" numbers stamped somewhere. Link to comment https://www.classiczcars.com/forums/topic/618-serial-number-location/#findComment-1579 Share on other sites More sharing options...
December 25, 200123 yr comment_1585 I'm not sure about the 240Z, but on my Fairlady Z's, both had the number stamped into the firewall. This was on the side nearest the master cylinder. Perhaps on the other side in a 240Z? Hope this helps...Bob Link to comment https://www.classiczcars.com/forums/topic/618-serial-number-location/#findComment-1585 Share on other sites More sharing options...
December 26, 200123 yr Author comment_1588 do the Fairladus also have the riveted tag at the windshield? Link to comment https://www.classiczcars.com/forums/topic/618-serial-number-location/#findComment-1588 Share on other sites More sharing options...
December 26, 200123 yr comment_1589 Neither of my Fairladys has an ID on the dash. One was a '70, and the other a '73...Bob Link to comment https://www.classiczcars.com/forums/topic/618-serial-number-location/#findComment-1589 Share on other sites More sharing options...
December 26, 200123 yr comment_1594 I believe the serial number is stamped into the firewall, behind the top of the brake master cylinder.Marty Link to comment https://www.classiczcars.com/forums/topic/618-serial-number-location/#findComment-1594 Share on other sites More sharing options...
December 30, 200123 yr Author comment_1634 found it, thanks Link to comment https://www.classiczcars.com/forums/topic/618-serial-number-location/#findComment-1634 Share on other sites More sharing options...
