My recollection of the exhaust manifold on my car was no finish - just bare casting (that quickly rusted!).  I have heat shields from both pre-heat riser and post-heat riser.  They appear to be clear zinc finish.
  • 3 weeks later...
4 minutes ago, zspert said:
Hoover,
Your left motor mount bracket should be engine blue while  your right bracket should be satin black.
Interestingly I just went out to take a look. Mine was painted as stated, some spots on the left bracket the blue was chipped it was black below. So it looks like they mounted the bracket to the engine before painting the engine because I found blue paint in the seem between the rubber mount also but not between the bracket and the mount.  Also no paint between the mount and the block.
Hope that helps someone
