Need a plug bolt
Diseazd
Took the white 70 for some exercise. Developed an exhaust leak (loud). Found the cause....she’s missing a bolt (plug) from her early exhaust manifold. Anyone know the thread size of this item, or better jet do they have one they could spare?
Thanks
Guy
Is that not the narrow band O2 sensor location from a ZX manifold?  Never seen an early manifold with a need for either an EGR fitting or O2 sensor that would explain that hole. Unless it was a later user added "feature"
Anyway if its O2 bung thread, its M18x 1.5.
https://www.google.com/search?q=280zx+exhaust+manifold&rlz=1C9BKJA_enCA668CA668&oq=280zx+exhaust+manifold&aqs=chrome..69i57j0l3.6099j1j7&hl=en-US&sourceid=chrome-mobile&ie=UTF-8#imgrc=wbMsjPBtTsxSnM:
Edited by zKars
Right you are Jim. It’s not an early manifold, it’s a manifold from a ZX with no exhaust tubes......W48. I tried 3/8 and 1/2 inch plugs.....one too small and one too large. I just want to plug it. I’ll order an M18x1.5 plug. Thanks so much for your help.....I am always impressed with your knowledge of Z cars.
Regards
Guy
Regards
Guy
They will probably have one at your local big box parts store too.
1 hour ago, zKars said:
Glad to help.  Speed shops that sell weld in O2 bungs will also have plugs. Some of the bungs I've bought actually came with the plug.
Great....I just ordered 2 bungs with the M18x1.5 plugs. One for each of the two Stroker Motors (I’ll have them welded in the Dow pipes). Curious as to how the A/F ratio is with the SU’s. Have you ever checked your Stroker with the SU’s? If so, what were your numbers?
I had a great experience with my SU's with the stroker motor. Nearly equal performance in the low/mid range as the Mikuni 44's I had previously, excellent mileage, easy starting etc. AFR's with N47 needles on cruise at 15'ish, 12-13 at WOT
Perfect.....Yes I love the way the strokers pull with the SU’s and their simplicity. Just didn’t know if they were lean at WOT.
Thanks
  • Who's Online   3 Members, 0 Anonymous, 339 Guests (See full list)
