1976 280z engine runs rough then dies, will not idle.
mbz
17 minutes ago, Dave WM said:
only other far out possibility is a Godzilla pump putting out so much volume it just overwhelms the system.
I'm checking service records now, looked back to 2008 and did not see any mention of fuel pump replacement.
I'm going to button her up for the night, then do a deep dig on service records to see if I can find out when it was last replaced.
What's the next step....?
New fuel pump?
Testing the vacuum from the intake manifold to the FPR?
Kinda stumped here.
Thanks for the help today guys, I appreciate you putting up with my amateur BS.
Edited by mbz
18 minutes ago, Dave WM said:
only other far out possibility is a Godzilla pump putting out so much volume it just overwhelms the system. I am going to do some test on volume as well (a timed measurement). outside of that I am all out of suggestions.
I think that we've all been just farting around with a bad gauge the whole time.  Pittsburgh is a Harbor Freight brand.  It's been fun.  I have three gauges in my garage, two good ones and bad one (but with a known offset).
His FPR's are probably fine.  The AFM has probably been adjusted, by somebody, in the past.  Might have some high resistance on the coolant temperature circuit.
But, without "knowns" you're just stumbling around in the dark.
Edited by Zed Head
Well I'm trying to provide relevant info.
What other tests and results would you like to see?
Just now, Zed Head said:
Actually it's a sign of inconsistency.  The gauge was stuck at 3 for a while, then it's at 0.  It fits the overall randomness of the readings from that gauge.
OK so as to the gauge and it's consistency..... I GET IT.
I will borrow one from Pep Boys tomorrow and see if I get different results.
Flogging a dead horse on that point.
You're not really winning anything by showing that your previous posts were unclear.  You're just showing that what I said was right.  The needle stop is zero.
Not trying to win anything Zed, just trying to fix my car.
It's not a competition.
