April 4, 20196 yr comment_572573 1 hour ago, ryanotown22 said: I use the rear diff block plate and the front crossmember in the middle Sent from my iPhone using Tapatalk Me to. Link to comment https://www.classiczcars.com/forums/topic/61849-picking-up-a-1977-280z-6-hours-away-tips/?&page=4#findComment-572573 Share on other sites More sharing options...
April 4, 20196 yr Author comment_572575 What does the rear diff block plate looks like? Sorry, I'm not too sure what to look for ? Link to comment https://www.classiczcars.com/forums/topic/61849-picking-up-a-1977-280z-6-hours-away-tips/?&page=4#findComment-572575 Share on other sites More sharing options...
April 4, 20196 yr comment_572576 16 minutes ago, siteunseen said: I thought it was passengers rear, the farthest from the m/c? I've been doing it wrong! Not a big deal though, it stops. Hey Cliff, it's deceptive, the rear brake line on the driver side is actually longer than the passenger side.... who knew Link to comment https://www.classiczcars.com/forums/topic/61849-picking-up-a-1977-280z-6-hours-away-tips/?&page=4#findComment-572576 Share on other sites More sharing options...
April 4, 20196 yr comment_572577 I just put the jack right under the diff.Sent from my SM-G950U1 using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/61849-picking-up-a-1977-280z-6-hours-away-tips/?&page=4#findComment-572577 Share on other sites More sharing options...
April 4, 20196 yr comment_572584 2 hours ago, siteunseen said: I thought it was passengers rear, the farthest from the m/c? I've been doing it wrong! Not a big deal though, it stops. Me too - for over 50 years. I guess I'm lucky to still be alive. Dennis Link to comment https://www.classiczcars.com/forums/topic/61849-picking-up-a-1977-280z-6-hours-away-tips/?&page=4#findComment-572584 Share on other sites More sharing options...
April 6, 20196 yr Author comment_572756 Yesterday I was able to finish putting in the resurfaced drum rotors and brake shoes. Today I'll be doing the front brakes. My turn signal and headlight/windshield wiper combo aren't working. Where would be a good place to check it out? I bought electrical cleaner yesterday. Link to comment https://www.classiczcars.com/forums/topic/61849-picking-up-a-1977-280z-6-hours-away-tips/?&page=4#findComment-572756 Share on other sites More sharing options...
April 6, 20196 yr comment_572760 You might want to read this. Then after getting it to work, install a relay for your headlights. http://woodworkerb.com/home/datsun-240z-rebuild/blinker-detail/ Edited April 6, 20196 yr by Jeff Berk Link to comment https://www.classiczcars.com/forums/topic/61849-picking-up-a-1977-280z-6-hours-away-tips/?&page=4#findComment-572760 Share on other sites More sharing options...
April 16, 20196 yr Author comment_573401 Hi guys, I did some work on the Z today. I replaced the fuel filter, transmission fluid. I need to replace the fuel injector because I have one that is not firing. Should I replace all 6 or just the one not working? Is it okay to buy a re-manufactured injector? Do you guys advise buying this set: https://www.ebay.com/p/Set-of-Six-Factory-Reman-Nissan-OEM-Injectors-1975-83-280z-ZX-2-8l-Non-Turbo/24013354735?iid=201509531117&chn=ps Link to comment https://www.classiczcars.com/forums/topic/61849-picking-up-a-1977-280z-6-hours-away-tips/?&page=4#findComment-573401 Share on other sites More sharing options...
April 16, 20196 yr comment_573410 It would be smart to replace all 6 as a matched set unless the budget does not allow it. To get to one, you have access to all at that time. Renews all the seals & the short fuel lines. The Ebay set looks good to me, price wise and they are Nissan. My 2 cents. Link to comment https://www.classiczcars.com/forums/topic/61849-picking-up-a-1977-280z-6-hours-away-tips/?&page=4#findComment-573410 Share on other sites More sharing options...
April 16, 20196 yr comment_573412 10 hours ago, BayAreaZ650 said: Hi guys, I did some work on the Z today. I replaced the fuel filter, transmission fluid. I need to replace the fuel injector because I have one that is not firing. Should I replace all 6 or just the one not working? Is it okay to buy a re-manufactured injector? Do you guys advise buying this set: https://www.ebay.com/p/Set-of-Six-Factory-Reman-Nissan-OEM-Injectors-1975-83-280z-ZX-2-8l-Non-Turbo/24013354735?iid=201509531117&chn=ps are you sure its the injector and not the wire connection to the injector? They often become corroded and you end up with poor contact of the pins. I don't know exactly what is done to refurbish injectors, they don't look to be rebuildable other than replacing the small filter screen and plastic cap on the tip. There are places that offer cleaning services if its just a matter of improving the flow. Link to comment https://www.classiczcars.com/forums/topic/61849-picking-up-a-1977-280z-6-hours-away-tips/?&page=4#findComment-573412 Share on other sites More sharing options...
April 16, 20196 yr comment_573415 What he said. You might not have to replace ANY injectors. Have you verified that the issue is inside the injector itself and not something else? Link to comment https://www.classiczcars.com/forums/topic/61849-picking-up-a-1977-280z-6-hours-away-tips/?&page=4#findComment-573415 Share on other sites More sharing options...
April 16, 20196 yr comment_573416 Assuming he does indeed have a bad injector, you guys are cheap.. Link to comment https://www.classiczcars.com/forums/topic/61849-picking-up-a-1977-280z-6-hours-away-tips/?&page=4#findComment-573416 Share on other sites More sharing options...
