Posted March 31, 20196 yr comment_572274 Does anyone knows what size and type of round rubber seals go in these holes on the floor behind theĀ seats? Who sells them? Link to comment https://www.classiczcars.com/forums/topic/61922-size-and-type-of-rubber-grommets-on-1972-240z/ Share on other sites More sharing options...
April 1, 20196 yr comment_572342 If it's a 20mm hole, Banzai Motorsports were the only source when I last checked a couple of years ago.Ā Things may have changed since then.Ā Check the usual suppliers. If it's a 25mm hole, both Banzai and Motorsport Auto (and probably others) can help you out. Link to comment https://www.classiczcars.com/forums/topic/61922-size-and-type-of-rubber-grommets-on-1972-240z/#findComment-572342 Share on other sites More sharing options...
April 1, 20196 yr Author comment_572344 Maybe i should measure the diameter with a caliper first. Link to comment https://www.classiczcars.com/forums/topic/61922-size-and-type-of-rubber-grommets-on-1972-240z/#findComment-572344 Share on other sites More sharing options...
April 1, 20196 yr comment_572347 44 minutes ago, jalexquijano said: Maybe i should measure the diameter with a caliper first. Yes Link to comment https://www.classiczcars.com/forums/topic/61922-size-and-type-of-rubber-grommets-on-1972-240z/#findComment-572347 Share on other sites More sharing options...
April 2, 20196 yr Author comment_572400 Any idea of what is the correct rubber plug? Link to comment https://www.classiczcars.com/forums/topic/61922-size-and-type-of-rubber-grommets-on-1972-240z/#findComment-572400 Share on other sites More sharing options...
April 2, 20196 yr comment_572405 Start with the size Link to comment https://www.classiczcars.com/forums/topic/61922-size-and-type-of-rubber-grommets-on-1972-240z/#findComment-572405 Share on other sites More sharing options...
April 2, 20196 yr comment_572469 18 hours ago, jalexquijano said: Any idea of what is the correct rubber plug? First find the size, then get a plug for that size. Link to comment https://www.classiczcars.com/forums/topic/61922-size-and-type-of-rubber-grommets-on-1972-240z/#findComment-572469 Share on other sites More sharing options...
April 3, 20196 yr Author comment_572530 Just took the measure with a caliper. Its 20mm! Who sells this size of rubber plug? Link to comment https://www.classiczcars.com/forums/topic/61922-size-and-type-of-rubber-grommets-on-1972-240z/#findComment-572530 Share on other sites More sharing options...
April 4, 20196 yr comment_572592 On 4/1/2019 at 7:55 AM, Namerow said: If it's a 20mm hole, Banzai Motorsports were the only source when I last checked a couple of years ago.Ā Things may have changed since then.Ā Check the usual suppliers.ļ»æ If it's a 25mm hole, both Banzai and Motorsport Auto (and probably others) can help you out. Ā Link to comment https://www.classiczcars.com/forums/topic/61922-size-and-type-of-rubber-grommets-on-1972-240z/#findComment-572592 Share on other sites More sharing options...
April 5, 20196 yr Author comment_572679 I just sent him an e-mail. Hope he responds. Link to comment https://www.classiczcars.com/forums/topic/61922-size-and-type-of-rubber-grommets-on-1972-240z/#findComment-572679 Share on other sites More sharing options...
April 10, 20195 yr Vendor comment_572991 We've had them available for quite some time now.Ā We offer various plugsĀ depending on the size that you need. https://www.thezstore.com/page/TZS/PROD/classic03a13/30-8004 Ā Link to comment https://www.classiczcars.com/forums/topic/61922-size-and-type-of-rubber-grommets-on-1972-240z/#findComment-572991 Share on other sites More sharing options...
