Posted April 1, 20196 yr comment_572365 Hi All, Jump into front air dam and rear spoiler. Neither purchase can with any hardware or instructions (I do read them), just the unpainted part. Air dam, can't mess that up but I was curious if there is a standard or proper location for the rear spoiler? Checked out a ton of pics, Is the answer flush with the hatchback lip? or should there be a space forward of the lip? Rear spoiler 432 style, two mounting bolts. Any diagram or advise would help. Link to comment https://www.classiczcars.com/forums/topic/61929-rear-spoiler-fitment/ Share on other sites More sharing options...
April 1, 20196 yr comment_572368 here's my rear spoiler as mounted from the dealership in 1972. It's mounted right before the hatch rolls down. That was one of the hardest things I've done that I thought would be easy. Take the vinyl cover off the interior side bottom of the hatch to access the bolts. Getting the nuts on are a huge pain in the rectum. Good luck! Not my car but the 432 google search... https://www.google.com/search?q=mounting+rear+spoiler+classiczcars.com&rlz=1C1BOFA_enUS494US494&oq=mounting+rear+spoiler+classiczcars.com&aqs=chrome..69i57.11718j1j7&sourceid=chrome&ie=UTF-8 Edited April 1, 20196 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/61929-rear-spoiler-fitment/#findComment-572368 Share on other sites More sharing options...
April 1, 20196 yr comment_572385 3 hours ago, Blitzed said: Rear spoiler 432 style, two mounting bolts Just two? Mine has six. Also had no pattern or instructions. Link to comment https://www.classiczcars.com/forums/topic/61929-rear-spoiler-fitment/#findComment-572385 Share on other sites More sharing options...
April 1, 20196 yr comment_572387 Link to comment https://www.classiczcars.com/forums/topic/61929-rear-spoiler-fitment/#findComment-572387 Share on other sites More sharing options...
April 1, 20196 yr comment_572390 My 2c... Dont drill, use tape. Link to comment https://www.classiczcars.com/forums/topic/61929-rear-spoiler-fitment/#findComment-572390 Share on other sites More sharing options...
April 1, 20196 yr comment_572391 2 minutes ago, moelk said: My 2c... Dont drill, use tape. If I ever do it again tape will be used. I did put rubber fender washers under the bolts. Keeps the spoiler off the paint. Link to comment https://www.classiczcars.com/forums/topic/61929-rear-spoiler-fitment/#findComment-572391 Share on other sites More sharing options...
April 1, 20196 yr comment_572393 10 minutes ago, siteunseen said: If I ever do it again tape will be used. I did put rubber fender washers under the bolts. Keeps the spoiler off the paint. Good point on the rubber washers Site. I used rubber “O” rings under each bolt......not only does it keep the spoiler off the paint, but allows water to pass through for drying purposes and by sealing the bolts, it keeps water out of the holes in the deck. Link to comment https://www.classiczcars.com/forums/topic/61929-rear-spoiler-fitment/#findComment-572393 Share on other sites More sharing options...
April 2, 20196 yr comment_572402 1 hour ago, Diseazd said: Good point on the rubber washers Site. I used rubber “O” rings under each bolt......not only does it keep the spoiler off the paint, but allows water to pass through for drying purposes and by sealing the bolts, it keeps water out of the holes in the deck. Great minds and all that jazz... I too used small "O" rings to seal each of the six bolts when reinstalling my spoiler. Link to comment https://www.classiczcars.com/forums/topic/61929-rear-spoiler-fitment/#findComment-572402 Share on other sites More sharing options...
April 2, 20196 yr comment_572413 What tape would y'all recommend? Link to comment https://www.classiczcars.com/forums/topic/61929-rear-spoiler-fitment/#findComment-572413 Share on other sites More sharing options...
April 2, 20196 yr comment_572446 If you tape and have to remove the spoiler in the future the paint will likely come off no? Link to comment https://www.classiczcars.com/forums/topic/61929-rear-spoiler-fitment/#findComment-572446 Share on other sites More sharing options...
April 2, 20196 yr comment_572454 16 hours ago, jfa.series1 said: Great minds and all that jazz... I like your new picture Mr Arnett. She's a beauty! Link to comment https://www.classiczcars.com/forums/topic/61929-rear-spoiler-fitment/#findComment-572454 Share on other sites More sharing options...
April 2, 20196 yr comment_572455 15 hours ago, torynich said: What tape would y'all recommend? Here's a good read on 3M tape from EScanlon. Auto paint shops would have good info also. Link to comment https://www.classiczcars.com/forums/topic/61929-rear-spoiler-fitment/#findComment-572455 Share on other sites More sharing options...
