Posted April 4, 20196 yr comment_572622 Has anyone got any links to any good 2.7(ish) engine builds? I'm going the hard way about it(140mm rods etc) however looking forward to having something a little from the norm. I've got the last few bits on the way now so would like some interesting reading/research. Edited April 4, 20196 yr by Jason240z Link to comment https://www.classiczcars.com/forums/topic/61952-27-engine-builds/ Share on other sites More sharing options...
April 4, 20196 yr comment_572634 and I was just about to send you a link to this post - then I realised it's you!!!! [emoji1787] :p Ps. Seen this ?https://forums.hybridz.org/topic/102748-build-after-24-years/ Link to comment https://www.classiczcars.com/forums/topic/61952-27-engine-builds/#findComment-572634 Share on other sites More sharing options...
April 5, 20196 yr Author comment_572666 The curse of keeping the original block! Yes seen that one... just no more!! Link to comment https://www.classiczcars.com/forums/topic/61952-27-engine-builds/#findComment-572666 Share on other sites More sharing options...
April 5, 20196 yr comment_572667 There's this from Australia https://www.viczcar.com/forum/topic/15125-l24-stroker-build/ Link to comment https://www.classiczcars.com/forums/topic/61952-27-engine-builds/#findComment-572667 Share on other sites More sharing options...
April 5, 20196 yr Author comment_572671 2 hours ago, riceburner said: There's this from Australia https://www.viczcar.com/forum/topic/15125-l24-stroker-build/ Thats a lovely build there. He builds the best L series in the world though(probably!). I'm +3mm pistons(29mm pin) 280 crank 140mm rods so a lot more conventional. Link to comment https://www.classiczcars.com/forums/topic/61952-27-engine-builds/#findComment-572671 Share on other sites More sharing options...
November 20, 20204 yr comment_610743 I just fitted a stroker I built many years ago. Used a standard l24 block, l28 crank, l24 pistons and rods. Shaved the difference in the rods off the top of the dished pistons which ended up as flat tops. E88 head with some port work and mild can. Still running in but can feel a big improvement over my old stock l24. Link to comment https://www.classiczcars.com/forums/topic/61952-27-engine-builds/#findComment-610743 Share on other sites More sharing options...
