  • 6 months later...
@Flyzlo While the part number on the bag is for a 72, the switch looks like it is for a 73-76. The wiper control is the key. On the 72 the wiper has Off, Lo, and Hi. (Off and 2 dots). On the 73-76, the wiper has Off, Int, Lo, and Hi. (Off and 3 dots)
Having said that, how much to ship to Zip Code 30506?
Nissan parts guide shows part works from 09/71 - 07/73. Now having said that if your car does NOT have inter wipers this switch will not work. You could check the plugs to see if the inter was an extra plug and not hook that up. Then just bypass the first dot for full wipers. I have not done this and am not sure if it will work or not. The shipping charge 6 business days would be $25.00 from Canada.
Hope this helps.
  On 10/30/2019 at 5:26 PM, SteveJ said:
@Flyzlo
Easy there Stevo, me first.
That's a '73 240z headlight switch.
Is that dollar amount in Canadian  dollars?
Edited by dhp123166
You said you wanted 72 switches. That's definitely a 73 switch. LOL
I forgot to mention that I found a used 72 ( no inter) but need to check it out before I give you a price. It definitely will be less. I’ll check it out tomorrow and let you know.
