May 15, 20195 yr comment_575526 The thing about the mounts, including the trans and diff, is that they have a lot of rubber. So I didn't feel bad putting a little bit of tension on them. I levered things together and bolted them down. They settle and distort over the years anyway, and move a lot when in use. Link to comment https://www.classiczcars.com/forums/topic/62002-swapping-to-f54p90/?&page=5#findComment-575526 Share on other sites More sharing options...
May 16, 20195 yr comment_575566 As I recall, I ended up finding a set of oem mounts.....aftermarket set did not align up... Link to comment https://www.classiczcars.com/forums/topic/62002-swapping-to-f54p90/?&page=5#findComment-575566 Share on other sites More sharing options...
May 16, 20195 yr Author comment_575597 4 hours ago, GV Z Car said: As I recall, I ended up finding a set of oem mounts.....aftermarket set did not align up... Do you have a part number? Link to comment https://www.classiczcars.com/forums/topic/62002-swapping-to-f54p90/?&page=5#findComment-575597 Share on other sites More sharing options...
May 16, 20195 yr Author comment_575599 I have Westar EM-2401. Anyone know the correct bolt size? The threaded receiver is full of paint dont want to strip the thread and bore. Link to comment https://www.classiczcars.com/forums/topic/62002-swapping-to-f54p90/?&page=5#findComment-575599 Share on other sites More sharing options...
May 17, 20195 yr comment_575615 Oem motor mount p/n : 11220-N3300 Link to comment https://www.classiczcars.com/forums/topic/62002-swapping-to-f54p90/?&page=5#findComment-575615 Share on other sites More sharing options...
May 20, 20195 yr Author comment_575868 New gasket and fasteners Edited May 20, 20195 yr by Sailor Bob Link to comment https://www.classiczcars.com/forums/topic/62002-swapping-to-f54p90/?&page=5#findComment-575868 Share on other sites More sharing options...
May 21, 20195 yr comment_575885 Aren't you missing the reinforcing plates on the edges? Maybe they got rid of them with the F54 block. http://www.carpartsmanual.com/datsun/Z-1969-1978/engine-280z/cylinder-block Link to comment https://www.classiczcars.com/forums/topic/62002-swapping-to-f54p90/?&page=5#findComment-575885 Share on other sites More sharing options...
May 21, 20195 yr comment_575887 The longer bolts go for those rails I found out the hard way. Never found out the reason for those rails though. Link to comment https://www.classiczcars.com/forums/topic/62002-swapping-to-f54p90/?&page=5#findComment-575887 Share on other sites More sharing options...
May 21, 20195 yr Author comment_575889 I have the rails but i am using the base pan off the old engine. They looked kind of ratty. Im guessing i dont need them. replacement bolts are all the same length. Edited May 21, 20195 yr by Sailor Bob Link to comment https://www.classiczcars.com/forums/topic/62002-swapping-to-f54p90/?&page=5#findComment-575889 Share on other sites More sharing options...
May 21, 20195 yr comment_575899 I think that they reduce the odds of leaks. Maybe also strengthen the seal for when you bump the bottom of the pan on something. Link to comment https://www.classiczcars.com/forums/topic/62002-swapping-to-f54p90/?&page=5#findComment-575899 Share on other sites More sharing options...
May 21, 20195 yr Author comment_575903 5 hours ago, Zed Head said: I think that they reduce the odds of leaks. Maybe also strengthen the seal for when you bump the bottom of the pan on something. Yeah, you're quoting my conscience. Link to comment https://www.classiczcars.com/forums/topic/62002-swapping-to-f54p90/?&page=5#findComment-575903 Share on other sites More sharing options...
May 25, 20195 yr Author comment_576303 Flywheel prepped/installed. Had to lay the header on.... i think something moved. Link to comment https://www.classiczcars.com/forums/topic/62002-swapping-to-f54p90/?&page=5#findComment-576303 Share on other sites More sharing options...
