Posted April 18, 20195 yr comment_573538 Hey guys, I tried three times to lock the side shaft bolts (wheel side) in place, using loctite and new spring washers. After a couple of hundred miles, they loosen up again. Did someone have the same issue in the past and how did you fix this? Is there a certain orientation of the side shaft flange neccessary? Space is tight, but I managed to fasten the nuts with a long extension ultimately. Maybe they hold better now. BR Link to comment https://www.classiczcars.com/forums/topic/62012-side-shaft-bolts-loosen-how-do-i-lock-them-in-place/ Share on other sites More sharing options...
