‘78 Wiring wideband afr gauge
AZDatsun
Sorry about the description it was vague. it’s down where the air/heat controls are located. I removed those since I no longer run air/heat so I made a blanking plate for it it’s an AEM gauge I was thinking maybe a wire from the stereo harness
Looks like a good one.  Is the cig lighter switched though?  I seem to recall older cars where it was always powered.  It's right next to the horn and dome light which are always powered.  No biggy, you can add your own switch.
I know on the 240Z and 260Z the cigarette lighter has constant power. I will check the 78 FSM to see if it's the same.
What is the brand and part number of the FAM? There may be something online saying how much power it draws.
Ok yep the blue line for the radio worked for switched power and there were two black lines one didn’t seem to go to ground maybe to a speaker. The other was ground and it works perfect now.
  • Who's Online   0 Members, 0 Anonymous, 906 Guests (See full list)
