Replacement Door Plate
Mike
8 hours ago, Diseazd said:
Christmas in June! Congrats....what a great surprise.
Absolutely, I have no idea why I put them in such a random location!  It must have made sense at the time, I'm sure.
8 hours ago, Patcon said:
@Mike
I have a box of pop rivets that should be correct for the door plate. If you would like some...
@Patcon, sure I could use them.  Do you advise rivets over screws?  Not sure if screws would clear the door, though.
The plates in the door jamb are riveted. The one on the shock tower uses small screws. I think its best if they go back this way. PM an address and I will drop you some
Ok sending you my address in PM.  Thank you!!
Mike
