I have those - homemade style.  A bag of cheap hockey pucks with a slot milled thru them.  The bag had 12 pucks so I was able to give a set to a couple of buddies.  They also work perfectly with jack stands to get the entire car off the ground.
Thanks.  I know I can find other jack points, but it is so much easier to use the side pinch welds as designed.  I get tired of getting on the ground, centering under the front cross member or rear end to lift.
I was tempted to fab my own until I saw these.
23 hours ago, Namerow said:
Please explain your process (steps) for getting the whole car up on axle stands when using the pinchweld strips as the jacking point.
Hmmm I read that as support spots only, not necessarily complete car jacking from the pinch welds.
