May 25, 20195 yr comment_576282 Thanks for the reply and detail. I plan to pop off all the panels and go through replacing them all. My 71 also has a nice finish with mostly all new rubber except several grommets and I want to replace them all. Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/62072-exhaustfuel-smell-in-cabin/?&page=2#findComment-576282 Share on other sites More sharing options...
May 25, 20195 yr comment_576285 There is a hole under the antenna area for a water drain. Often the drain hose separates leaving a hole between the interior and muffler area. Link to comment https://www.classiczcars.com/forums/topic/62072-exhaustfuel-smell-in-cabin/?&page=2#findComment-576285 Share on other sites More sharing options...
