HappyZ Posted May 1, 2019 Author Share #13 Posted May 1, 2019 @SteveJ If it's not too much trouble, can you ask him if he uses the blocks that came with his unit, or if he purchased the pinch weld blocks. Any help is appreciated. Link to comment Share on other sites More sharing options...
SteveJ Posted May 1, 2019 Share #14 Posted May 1, 2019 1 hour ago, wadelester said: @SteveJ If it's not too much trouble, can you ask him if he uses the blocks that came with his unit, or if he purchased the pinch weld blocks. Any help is appreciated. He said, "The blocks themselves work fine, however, I am going to cut a groove in four of them to simulate the pinch weld blocks. I don't believe it is necessary to spend extra money for something that you can do yourself." Link to comment Share on other sites More sharing options...
HappyZ Posted May 1, 2019 Author Share #15 Posted May 1, 2019 thanks! Link to comment Share on other sites More sharing options...
SteveJ Posted May 1, 2019 Share #16 Posted May 1, 2019 FYI, Costco is offering the QJ 5000 for $999 https://www.costco.com/.product.100460313.html?&EMID=B2C_2019_0501_May_Savings Link to comment Share on other sites More sharing options...
SteveJ Posted May 1, 2019 Share #17 Posted May 1, 2019 Oh, and to line up the pinch welds for lifting, attach the blocks to the car with blue tape and raise the lift up to meet the blocks. 1 Link to comment Share on other sites More sharing options...
Marty Rogan Posted May 1, 2019 Share #18 Posted May 1, 2019 I have had the 3500 and the 5000 and really like them. I take my 5000 to the track with me all the time. And yes, it is heavy, but I think the added safety it provides over jack stands is well worth it. Plus, the newer design has wheels built in, so it helps compensate for the weight somewhat. Link to comment Share on other sites More sharing options...
NA&CH Posted May 9, 2019 Share #19 Posted May 9, 2019 I have the 5k from costco and love them. Used only on my nismo and worked great. I am getting ready to use on the 240 this weekend. Any pics of the ones who have used and where they lifted from? I assume pinch welds just never like to assume. Chris Link to comment Share on other sites More sharing options...
HappyZ Posted May 23, 2019 Author Share #20 Posted May 23, 2019 I'll post photos soon, but did have some troubles. I purchased the slotted blocks, so I used them. I placed the block right on each dimple in the pinch weld. My front/passenger side began to bend inward, so now I have a sizable dent under the rocker. I do have some rust issues, so I assume that may be the problem. Note: I did have success the first time I jacked it - it was the second time when I had problems with rocker. Link to comment Share on other sites More sharing options...
Patcon Posted May 23, 2019 Share #21 Posted May 23, 2019 The rocker metal is fairly thick. So denting it with the cars weight is probably a bad sign Link to comment Share on other sites More sharing options...
HappyZ Posted May 24, 2019 Author Share #22 Posted May 24, 2019 Agreed on the "bad sign". I'm going to get the chassis sorted before jacking it again...I really would like to save this car if I can, even if it costs me more than I should spend Link to comment Share on other sites More sharing options...
bingo Posted May 24, 2019 Share #23 Posted May 24, 2019 I have the 5K from Costco and yes it works great on a 240z, you do need to position carefully between the wheels. I cut slots in my blocks with a skill saw and it works great on the pinch welds. Love the blue tape idea, will try that next time. Overall I really like the unit, it gives enough room under the car to work comfortably, it is easy to use, and super stable. It is heavy to move around, but I just leave them next to my car so I just slide them under and lift it up. Link to comment Share on other sites More sharing options...
Patcon Posted May 24, 2019 Share #24 Posted May 24, 2019 47 minutes ago, wadelester said: Agreed on the "bad sign". I'm going to get the chassis sorted before jacking it again...I really would like to save this car if I can, even if it costs me more than I should spend These cars are quickly becoming valuable enough to justify pretty extreme repair efforts. Link to comment Share on other sites More sharing options...
