What is this engine part???
Zaspen
I have my engine apart to replace the head gasket and timing cover gasket and I noticed today a small pin on the bench.  I'm not positive it is from the engine but I have never seen it before.  On the bench I have had the oil pump, head, timing cover, thermostat housing and the chain tensioner.  It doesn't appear to have an oily film on it but It could have been cleaned while I have been cleaning parts and scraping gaskets.  It has a black coating on it and has one small area that shows wear.  Any thoughts?20190429_205938.jpg
It looks like it is metal - a roll pin to be more specific. The bottom of the distributor shaft on a 240 would have one. The small gap along it provides a press fit - so not likely it fell out. I can't recall where another one would be located on the parts you have removed. You don't indicate the year or engine you car has but I believe the ZX distributor has a plastic collar at the bottom where the pin is located. Perhaps the plastic broke and the pin fell out. Just a guess, I'm afraid.
Its a 72 240Z.  Its solid metal and sticks to a magnet.  It appears to have a black oxide finish with some wear down to the base metal.  It isn't a roll pin or a plastic rivet.  Picture attached at a different angle. I saw nothing on any of the parts diagrams that this could be but like I said it just appeared on my workbench.  Thanks!
