Howdy,
Looking at redoing some of the front end of my '70 240z.
A few questions have come up.
Should I replace the bushing in the lower control arm? A 49yr old car, it seems like a smart idea.
Should I use the stock one, or use a urethane version? Advantage or disadvantage?
Also, what is the the difference in the steering knuckle between an early 240 and later 240? I have seen a different ball joint offered, but not sure how to tell the difference between the two?
Thanks
Bob
OE-style rubber bushings are generally best for street cars, poly-type bushings are best for track cars.  Rubber bushings provide compliance in the suspension so that harsh impacts are absorbed and  not transmitted directly into the body.  They also provide a small amount of flex that is not wanted in a track car where the suspension must respond immediately and consistently to driver inputs.  With poly bushings the ride is very tightly controlled and more harsh.  I initially installed poly bushings with my resto, did not like the ride quality and immediately swapped everything out to rubber.  Some OE/OEM rubber bushings are NLA so poly is the only choice - the steering rack is a typical example.
The online catalog shows a change in the steering knuckle and ball joint beginning with build date 7007.  I think the ball joint size was increased for durability.  If your car is prior to this date, you'll need to locate a pair of steering knuckles from a later car to fit the currently available ball joints.  Here's the link to the catalog reference:
http://www.carpartsmanual.com/datsun/Z-1969-1978/axle/front-axle
Hope this helps.
  • 2 months later...
I'm restoring a 73 240 and interested to know how important it is to replace that lower control arm bushing? Or what's the best way to determine if it needs replacing?
Thanks
Thanks
At $12.14 each from Courtesy (plus shipping to you) how can you not do it?  Aftermarket is even less at Rockauto.
https://www.courtesyparts.com/oem-parts/nissan-bushing-link-54535e4100
Thanks for the advice and link!
