Posted May 7, 20195 yr comment_575010 Did a brake upgrade on my 240z which included a 280zx master cylinder. The two side bleeders made the air filter cover not fit so we cut the ends off them and it fits now but scrapes still. Can I replace these with 7mm x 1 bolts so the clearance is better or does it require special plugs? Thanks. Link to comment https://www.classiczcars.com/forums/topic/62127-master-cylinder-plug/ Share on other sites More sharing options...
May 7, 20195 yr comment_575018 Brake bleeders have a special shape and a special material so they seat properly. They are the proper piece for the location. Find another solution... Link to comment https://www.classiczcars.com/forums/topic/62127-master-cylinder-plug/#findComment-575018 Share on other sites More sharing options...
