  • 4 weeks later...
  On 6/8/2019 at 5:53 PM, Patcon said:
When one of the brake circuits (front or back) fails, there is a piston in there that slides and illuminates the brake light in the speedometer
The brakes need to be “pumped” to actuate the piston in this device. The piston then blocks the defective line and shuttles all fluid to the working brakes. Quite ingenious really.
... as long as you remember to pump the brakes when they fail!
