jfa.series1 Posted May 29, 2019 Share #13 Posted May 29, 2019 1 hour ago, donnie.petway said: There's a lot of info yall are telling me I had no clue about You'll find that most of us are compulsive in that way. The anal retentiveness has to come out. 2 1 Link to comment https://www.classiczcars.com/topic/62244-1970-240z-restoration-engine-ideas/?page=2#findComment-576519 Share on other sites More sharing options...
240260280 Posted May 29, 2019 Share #14 Posted May 29, 2019 I saw this car for sale around Boston last fall on CL. It was a good price!!! Link to comment https://www.classiczcars.com/topic/62244-1970-240z-restoration-engine-ideas/?page=2#findComment-576527 Share on other sites More sharing options...
donnie.petway Posted May 29, 2019 Author Share #15 Posted May 29, 2019 The vin number is HLS30-12186 I couldn't find any number stamp on the engine though Link to comment https://www.classiczcars.com/topic/62244-1970-240z-restoration-engine-ideas/?page=2#findComment-576536 Share on other sites More sharing options...
Patcon Posted May 29, 2019 Share #16 Posted May 29, 2019 1 hour ago, donnie.petway said: The vin number is HLS30-12186 I couldn't find any number stamp on the engine though there is a flat pad on the upper left corner of the block on the passenger side. There are numbers engraved in it. They can be difficult to read sometimes Link to comment https://www.classiczcars.com/topic/62244-1970-240z-restoration-engine-ideas/?page=2#findComment-576539 Share on other sites More sharing options...
siteunseen Posted May 29, 2019 Share #17 Posted May 29, 2019 (edited) It's betweem the back 2 plugs... Edited May 29, 2019 by siteunseen 1 Link to comment https://www.classiczcars.com/topic/62244-1970-240z-restoration-engine-ideas/?page=2#findComment-576540 Share on other sites More sharing options...
Terrapin Z Posted May 29, 2019 Share #18 Posted May 29, 2019 As has been noted above this does look like a late 70 or early 71. (possibly sold as a 71) The vin collaborates that as well. There is usually a build date plate inside the drivers door jam that will have a month / year when the car was built. My guess is Nov or Dec of 1970 The Drivers side strut tower should have a vin plate screwed on that will have the vin number and engine number. The stamp on the motor should be found in the circled area. You might have to clean it off some to see it. I have seen vin plates missing, or painted over. All this will tell you is if the engine is original to the car. If it is they are worth more being left that way, again as mentioned above. All in all it looks unmolested, I would keep it that way if it were mine. I do also understand the allure to add big HP and mod it up. I'd say we ^ would just like to help you make a more informed decision on what to do with it, as that was your original question. Ultimately it is your choice. 2 Link to comment https://www.classiczcars.com/topic/62244-1970-240z-restoration-engine-ideas/?page=2#findComment-576541 Share on other sites More sharing options...
donnie.petway Posted May 29, 2019 Author Share #19 Posted May 29, 2019 I checked the door it was manufactured in October 1970 I also found the plate on the engine sadly it's very dirty and I have nothing to scrape the rust. Should I go ahead and rebuild the suspension and brakes before I get into the engine that way it's already done? Link to comment https://www.classiczcars.com/topic/62244-1970-240z-restoration-engine-ideas/?page=2#findComment-576543 Share on other sites More sharing options...
siteunseen Posted May 29, 2019 Share #20 Posted May 29, 2019 (edited) What!?!? Sandpaper, wire brush, steel wool, your toothbrush... I'm sorry. You're new to this. Edited May 29, 2019 by siteunseen Link to comment https://www.classiczcars.com/topic/62244-1970-240z-restoration-engine-ideas/?page=2#findComment-576544 Share on other sites More sharing options...
Terrapin Z Posted May 29, 2019 Share #21 Posted May 29, 2019 No, before you rebuild the brakes and motor, unscrew the vin plate from the strut tower. Clean the plate enough to see the indented numbers, Post your findings!! 1 Link to comment https://www.classiczcars.com/topic/62244-1970-240z-restoration-engine-ideas/?page=2#findComment-576546 Share on other sites More sharing options...
donnie.petway Posted May 29, 2019 Author Share #22 Posted May 29, 2019 Will do thank you for all the advice yall have given me 2 Link to comment https://www.classiczcars.com/topic/62244-1970-240z-restoration-engine-ideas/?page=2#findComment-576547 Share on other sites More sharing options...
240260280 Posted May 29, 2019 Share #23 Posted May 29, 2019 Hi Donnie, If you send me a PM with your phone number and a time to call, I'd be happy to help answer questions and discuss things. btw you have a great car there. Be sure to keep every part you change. They are valuable. Link to comment https://www.classiczcars.com/topic/62244-1970-240z-restoration-engine-ideas/?page=2#findComment-576548 Share on other sites More sharing options...
donnie.petway Posted May 29, 2019 Author Share #24 Posted May 29, 2019 I was able to clean the engine number however the vin plate on the tower is missing Link to comment https://www.classiczcars.com/topic/62244-1970-240z-restoration-engine-ideas/?page=2#findComment-576551 Share on other sites More sharing options...
