Whining sound when lights on
AZDatsun
I noticed lately when I start my car it seems like it takes a bit for the RPMs to stabilize and is down to around 500 rpm and my voltage gauge fluctuates a lot when i first start it. so I give it some gas to keep it going until it’s more warmed up. During these first few minutes my lights are also dimmer until I get it up to around 800+ rpm. Also when I turn on the headlights I get a noise coming from the alternator that used to not be there. Do you think it’s time for a new alternator?
My belt looks fine and is less than a year old
I went out and got timings
There are no accessories on other than the parking brake light on the speedo guage, AEM afr gauge, and the stock clock when I start the car. The clock obviously is always on.
13.5 just off trickle charger
12.92 7:22am
12.83 7:59am
12.75 8:47am
12.72 9:26am
12.71 10:24am
Started car and stabilized to 800rpm
13.44 10:26am
13.51 10.27am
13.52 10:28am
13.52 10:30am
13.50 10:31am
13.49 10:32am
13.48 10:33am
13.46 10:33am
13.45 10:34 am
Shut car off and leaving off trickle charger for now
13.42 10:35am
13.16 10:54am
 12.95 11:42am
12.89 11:58am
I noticed if I give it throttle above 800rpm the voltage does increase but the steady decrease is worrisome I think.
The alternator is a rock auto bought it in March 2017
ACDELCO 3341558 (334-1558@A23)
Looks like it’s only a 24 month warranty darn!
I just did a parasitic draw test (I hope correctly) by unhooking the negative battery cable and connecting one volt meter lead to the negative post and the other lead to the negative battery cable and I set my volt meter to dca 10amp and I got a reading of between 0.01 and 0.02 so I think that means there is no drain going on
I agree the voltage numbers look pretty good. Someone else could probably chime in but the voltage going down, might just be the charge leveling out in the battery. Not my specialty. Since the voltages are good and it doesn't appear the alternator is being worked overly hard, then I would suspect the noise is from the alternator, but it does appear to be working properly.
Keeping on monitoring battery levels drop seems to be leveling out. So maybe it is just getting back to 12.66. Looks like I will be purchasing a new alternator.
Shut car off
13.42 10:35am
13.16 10:54am
12.95 11:42am
12.89 11:58am
12.84 12:20pm
12.76 1:38pm
12.75 2:58pm
12.75 4:38pm
  • Who's Online   2 Members, 0 Anonymous, 991 Guests (See full list)
