Posted June 13, 20195 yr comment_577561 Hello everyone, and thanks in advance for any help you can give me. My 1976 280z was running fine last time I drove it, but after sitting in the CA sun for 2 years, I'm struggling to get it back on the road. After draining out the old gas, I have a new battery, new spark plugs, and a couple gallons of new gas in. When I go to start it, all I get is cranking, and no turn over, and I have yet to hear the fuel pump cone on. I've tried moving the new battery to the rear and getting 12v to the fuel pump directly, but this doesn't get the fuel pump going either, just a click. I also don't seem to be getting power to the fuel pump when cranking. Any ideas on what might be going on, or existing threads on this that I can go off of would be greatly appreciated. Thank you, Oscar **Also zero fuel pressure when cranking** *Reading taken under the hood, after the fuel filter* Edited June 13, 20195 yr by redfairladyzee Link to comment https://www.classiczcars.com/forums/topic/62327-sitting-for-2-years-wont-start/ Share on other sites More sharing options...
June 13, 20195 yr comment_577564 Have you checked for power at the pump with a gauge or test light? Try hitting the pump with a hard object. Sometimes, they just get stuck when not used for a while. Dennis Link to comment https://www.classiczcars.com/forums/topic/62327-sitting-for-2-years-wont-start/#findComment-577564 Share on other sites More sharing options...
June 13, 20195 yr comment_577566 Welcome Oscar! If 12V direct to the pump does not make it hum then it seems to be dead. There is a device in the front of the car called an airflow meter (AFM) it has a mechanical switch that sends power to the pump when cranking. These can stick or corrode. Have a look here: http://atlanticz.ca/zclub/techtips/EFI&fuel.htm Link to comment https://www.classiczcars.com/forums/topic/62327-sitting-for-2-years-wont-start/#findComment-577566 Share on other sites More sharing options...
June 13, 20195 yr comment_577570 51 minutes ago, redfairladyzee said: Hello everyone, and thanks in advance for any help you can give me. My 1976 280z was running fine last time I drove it, but after sitting in the CA sun for 2 years, I'm struggling to get it back on the road. After draining out the old gas, I have a new battery, new spark plugs, and a couple gallons of new gas in. When I go to start it, all I get is cranking, and no turn over, and I have yet to hear the fuel pump cone on. I've tried moving the new battery to the rear and getting 12v to the fuel pump directly, but this doesn't get the fuel pump going either, just a click. I also don't seem to be getting power to the fuel pump when cranking. Any ideas on what might be going on, or existing threads on this that I can go off of would be greatly appreciated. Thank you, Oscar **Also zero fuel pressure when cranking** *Reading taken under the hood, after the fuel filter* Since you directly connected the pump to the battery and it didn't turn then the pump is dead. Just go get a new pump or try @psdenno's idea and give it a smack. Also, if you have the ability (air hose) try and blow out the metal fuel line (with the pump and fuel filter hoses disconnected of course. Edited June 13, 20195 yr by chaseincats Link to comment https://www.classiczcars.com/forums/topic/62327-sitting-for-2-years-wont-start/#findComment-577570 Share on other sites More sharing options...
June 13, 20195 yr Author comment_577573 Awesome, thank you all for such quick replies!! Will definitely check out the EFI Bible linked and also give the fuel pump a smack just in case it can save me a few bucks ? Will update you guys soon. ? Link to comment https://www.classiczcars.com/forums/topic/62327-sitting-for-2-years-wont-start/#findComment-577573 Share on other sites More sharing options...
June 13, 20195 yr comment_577574 ditto on a new pump, why trust it after sitting for two years, Personally I would get a new NISSAN pump, about 250$ but if the pump stops your are dead in the water, so I like OE. Link to comment https://www.classiczcars.com/forums/topic/62327-sitting-for-2-years-wont-start/#findComment-577574 Share on other sites More sharing options...
June 14, 20195 yr Author comment_577645 It doesn't run as great as I remember, but I did get it to start!!!! Thanks to all of you for your replies!! Smacking the unit didn't work this time, so I went with a cheapo part from my local store just to get the project going. Will definitely look at an OE option soon. ?? Link to comment https://www.classiczcars.com/forums/topic/62327-sitting-for-2-years-wont-start/#findComment-577645 Share on other sites More sharing options...
June 14, 20195 yr comment_577646 5 minutes ago, redfairladyzee said: It doesn't run as great as I remember, but I did get it to start!!!! Thanks to all of you for your replies!! Smacking the unit didn't work this time, so I went with a cheapo part from my local store just to get the project going. Will definitely look at an OE option soon. ?? It's been sitting for two years. It's not going to run great with out some diligent work. Connections need to be cleaned and there may be varnish in the fuel system that may have to be dealt with Link to comment https://www.classiczcars.com/forums/topic/62327-sitting-for-2-years-wont-start/#findComment-577646 Share on other sites More sharing options...
June 15, 20195 yr comment_577755 I had a bad fuel pump when I bought my car. Sat foe 18 yrs. I pulled it out and after tapping on it with 12V power applied it all of a sudden began to run. Never had a problem again with it . I also cleaned the screen in it. I agree with getting an OEM pump. They’re actually extremely durable and I heard the aftermarket ones are hit or miss. You need to confirm your are getting 36 PSI to the injectors if it’s still running bad. Most guys buy a $20 inline pressure gauge and install it in the line exiting the fuel filter. It’s a good diagnostic tool also for future issues. Good luck. Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/62327-sitting-for-2-years-wont-start/#findComment-577755 Share on other sites More sharing options...
June 16, 20195 yr comment_577786 On 6/13/2019 at 9:48 PM, Dave WM said: if the pump stops your are dead in the water, so I like OE. This is certainly true for many parts.. Link to comment https://www.classiczcars.com/forums/topic/62327-sitting-for-2-years-wont-start/#findComment-577786 Share on other sites More sharing options...
