June 28, 20195 yr comment_578538 When you have some reading time here's where I started. Thanks @240260280 http://atlanticz.ca/zclub/techtips/EFI&fuel.htm main page... http://atlanticz.ca/zclub/techtips/ Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=6#findComment-578538 Share on other sites More sharing options...
June 28, 20195 yr Author comment_578539 10 minutes ago, EuroDat said: You could have a couple of issues that cauld cause an overfueling problem. Most common are leaking injectors, leaking CSV or a bad temperature sensor or wiring going to the temperature sensor. The more resistance the colder the ECU thinks the engine is and compensates with more fuel. You seem to be getting a lot more fuel than a faulty temperature sensor would allow, but doing the checks will confirm or dismiss it. When you check it, do the check at the sensor (sensor to ground resitance) and than again at the ECU connector (Connector pin 13 to ground resistance) They should be the same. Refer to the bible for the correct resistance for temperature range. Note: Use the 1980 Bible. It is for all models 280Z, 280ZX en 810 Maximas up to 1980. The other book is for the 1974 to mid 1976 models. Sweet! Mines a 78 so I’ll use the former, all my injectors are new and while the CSV isn’t working, it also isn’t leaking, it’s completely gummed up with black soot, I’ll still be doing all the tests to be certain but I’m hoping I won’t have to buy injectors twice. Also for the tests what in line fuel pressure gauge do you use, my local auto parts stores don’t carry them for some reason and a lot of what I’ve been seeing online doesn’t look like it would work. Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=6#findComment-578539 Share on other sites More sharing options...
June 28, 20195 yr comment_578540 have you pulled that black cover off and tried fingering the sweeper vane in the AFM? I bought one and that thing was stuck by spider webs. 10 minutes and i had a good running '76 for dirt cheap.  Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=6#findComment-578540 Share on other sites More sharing options...
June 28, 20195 yr comment_578541 is there a harbor freight near you? they have them, 30$ish IIRC Â 90% chance its the CTS, either it or the wiring to it. It lives in a harsh environment (coolant) that can corrode not only the sensor but the connector to it as well if there is any kind of leak. Edited June 28, 20195 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=6#findComment-578541 Share on other sites More sharing options...
June 28, 20195 yr comment_578542 2 minutes ago, Jack Pearcy said: Sweet! Mines a 78 so I’ll use the former, all my injectors are new and while the CSV isn’t working, it also isn’t leaking, it’s completely gummed up with black soot, I’ll still be doing all the tests to be certain but I’m hoping I won’t have to buy injectors twice. Also for the tests what in line fuel pressure gauge do you use, my local auto parts stores don’t carry them for some reason and a lot of what I’ve been seeing online doesn’t look like it would work. you can get a pressure gauge from Lowes in the pool section. It's for the pool filters pressure. https://www.lowes.com/pd/aqua-ez-pressure-gauge/3151541?cm_mmc=shp-_-c-_-prd-_-lwn-_-google-_-lia-_-241-_-poolproducts-_-3151541-_-0&kpid&store_code=1640&k_clickID=go_1792976560_68785408469_346853782070_aud-299487635210:pla-416743622626_c_9012730&gclid=EAIaIQobChMIrNyVgeyM4wIVChgMCh0LowYKEAQYASABEgLOcfD_BwE Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=6#findComment-578542 Share on other sites More sharing options...
June 28, 20195 yr Author comment_578546 27 minutes ago, siteunseen said: When you have some reading time here's where I started. Thanks @240260280 http://atlanticz.ca/zclub/techtips/EFI&fuel.htm main page... http://atlanticz.ca/zclub/techtips/ Thanks it was a good read, I’ll be sure to reference it if I end up doing any AFM tuning, but I’ll wait until I run the tests like the instructions said Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=6#findComment-578546 Share on other sites More sharing options...
June 28, 20195 yr Author comment_578548 24 minutes ago, siteunseen said: you can get a pressure gauge from Lowes in the pool section. It's for the pool filters pressure. https://www.lowes.com/pd/aqua-ez-pressure-gauge/3151541?cm_mmc=shp-_-c-_-prd-_-lwn-_-google-_-lia-_-241-_-poolproducts-_-3151541-_-0&kpid&store_code=1640&k_clickID=go_1792976560_68785408469_346853782070_aud-299487635210:pla-416743622626_c_9012730&gclid=EAIaIQobChMIrNyVgeyM4wIVChgMCh0LowYKEAQYASABEgLOcfD_BwE That’ll do, thanks! Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=6#findComment-578548 Share on other sites More sharing options...
June 28, 20195 yr comment_578549 The wiring of the CTS and the CSV can get mixed up, bullet connectors and sensor plugs that can interchange. That's why its important to check at the 36 pin connector, it will account for any mixups. My guess is that pin 13 to ground will be wide open. Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=6#findComment-578549 Share on other sites More sharing options...
June 28, 20195 yr Author comment_578550 27 minutes ago, siteunseen said: have you pulled that black cover off and tried fingering the sweeper vane in the AFM? I bought one and that thing was stuck by spider webs. 10 minutes and i had a good running '76 for dirt cheap.  My AFM is brand new so I don’t think it’d be stuck but it might be worth a shot Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=6#findComment-578550 Share on other sites More sharing options...
June 28, 20195 yr comment_578551 2 minutes ago, Jack Pearcy said: My AFM is brand new so I don’t think it’d be stuck but it might be worth a shot If it's brand new I wouldn't do it. You'll have a brand new afm with a zip tyed plasic cover, not a good thing. ? Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=6#findComment-578551 Share on other sites More sharing options...
June 28, 20195 yr comment_578553 Have you looked at the throttle position switch? They cut in around 2,500rpm. Up until then they're on the low side, rpm, contact. Then at 2500 they are on neither for a second. Then they'll click onto wide open. Lots of info on those. Just a bunch of reading. https://www.google.com/search?client=ms-android-americamovil-us-revc&ei=2moWXf_gLqHm_Qb-3LY4&q=tps+classiczcars.com&oq=tps+classiczcars&gs_l=mobile-gws-wiz-serp.1.0.33i160l2.15674.26999..29083...0.0..0.160.1231.4j7......0....1.........41j33i299j30i10.a2JfS2XZEAA Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=6#findComment-578553 Share on other sites More sharing options...
June 28, 20195 yr Author comment_578556 22 minutes ago, siteunseen said: Have you looked at the throttle position switch? They cut in around 2,500rpm. Up until then they're on the low side, rpm, contact. Then at 2500 they are on neither for a second. Then they'll click onto wide open. Lots of info on those. Just a bunch of reading. https://www.google.com/search?client=ms-android-americamovil-us-revc&ei=2moWXf_gLqHm_Qb-3LY4&q=tps+classiczcars.com&oq=tps+classiczcars&gs_l=mobile-gws-wiz-serp.1.0.33i160l2.15674.26999..29083...0.0..0.160.1231.4j7......0....1.........41j33i299j30i10.a2JfS2XZEAA I messed around with mine, it would change slightly in rpm when I adjusted it but then go right back to 2500, I took a video but it won’t let me upload it Link to comment https://www.classiczcars.com/forums/topic/62337-78-280z-idle-problem/?&page=6#findComment-578556 Share on other sites More sharing options...
