June 20, 20195 yr Author comment_578088 Mark-Tom here agin! Below is a pic I took, ie...first one is fluid out of the damper second is off my engine dip stick. Also. a quick question. My master brake cylinder reservoirs, the smaller reservoir is almost empty, can I use DOT 3 fluid in there and be on my way?? thanks again! Tom Link to comment https://www.classiczcars.com/forums/topic/62358-engine-dampers/?&page=2#findComment-578088 Share on other sites More sharing options...
June 20, 20195 yr comment_578091 On 6/20/2019 at 11:25 PM, tom231 said: Mark-Tom here agin! Below is a pic I took, ie...first one is fluid out of the damper second is off my engine dip stick. Also. a quick question. My master brake cylinder reservoirs, the smaller reservoir is almost empty, can I use DOT 3 fluid in there and be on my way?? thanks again! Tom Steve gave you pretty good advise on the brake fluid before. If it were me I would use a DOT 3/4 compatible fluid. It won't surprise me if you have a leak somewhere. Many times a number of us are reading these threads but we don't get involved if you have already been given good advise Link to comment https://www.classiczcars.com/forums/topic/62358-engine-dampers/?&page=2#findComment-578091 Share on other sites More sharing options...
June 20, 20195 yr Author comment_578093 Mark-Tom here agin! Below is a pic I took, ie...first one is fluid out of the damper second is off my engine dip stick. Also. a quick question. My master brake cylinder reservoirs, the smaller reservoir is almost empty, can I use DOT 3 fluid in there and be on my way?? thanks again! Tom Link to comment https://www.classiczcars.com/forums/topic/62358-engine-dampers/?&page=2#findComment-578093 Share on other sites More sharing options...
June 20, 20195 yr Author comment_578094 Thanks! This is such a great site with GREAT PEOPLE!! Tom Link to comment https://www.classiczcars.com/forums/topic/62358-engine-dampers/?&page=2#findComment-578094 Share on other sites More sharing options...
June 21, 20195 yr comment_578100 @tom231 I'd add ATF. That's kind of what it looks like. I used Dexron but I doubt it'll make a difference. Link to comment https://www.classiczcars.com/forums/topic/62358-engine-dampers/?&page=2#findComment-578100 Share on other sites More sharing options...
June 21, 20195 yr Author comment_578101 Thanks Mark!! Tom Link to comment https://www.classiczcars.com/forums/topic/62358-engine-dampers/?&page=2#findComment-578101 Share on other sites More sharing options...
June 21, 20195 yr comment_578103 Mark, I wouldn't pull the carbs apart to get the old oil out. I just roll paper towels into a narrow cylinder and stick them down into the damper hole to soak up the old oil. Give it a few minutes to sop up the oil and then pull the paper out. Takes two or three rounds of paper wads to get the old stuff out. Taking the pistons out and turning them over to dump the oil out certainly works, but I consider it a risky maneuver with very little gain over just keeping them together and sponging it out instead. Respectively submitted, of course. Edited June 21, 20195 yr by Captain Obvious Link to comment https://www.classiczcars.com/forums/topic/62358-engine-dampers/?&page=2#findComment-578103 Share on other sites More sharing options...
June 21, 20195 yr comment_578110 I totally understand and agree. Long ago I used a turkey baster (No I didn't ask, Yes I caught Hell months later) and a piece of rubber tubing. My thought was, now would be a good time to clean up the internals a bit and lay hands on the subject of the discussion. Link to comment https://www.classiczcars.com/forums/topic/62358-engine-dampers/?&page=2#findComment-578110 Share on other sites More sharing options...
June 21, 20195 yr Author comment_578114 Would Dexron VI be backward compatible? Or look for a Dexron III if they still make it, ie...Peak? thanks, Tom Link to comment https://www.classiczcars.com/forums/topic/62358-engine-dampers/?&page=2#findComment-578114 Share on other sites More sharing options...
June 21, 20195 yr comment_578115 On 6/21/2019 at 1:40 AM, Captain Obvious said: I wouldn't pull the carbs apart to get the old oil out. Agree, Get a (empty old) handsoap pump and pump the most out... ( i Always use this when i renew the brakefluid! .. you take the pump out of the bottle and pump the fluid into the same bottle.. this way you don't make a mess with that brakefluid (or in your case the oil)) (When doing the brakes then you don't have to pump all the oil through the system and you can start with a container full of clean brakefluid.) ? Link to comment https://www.classiczcars.com/forums/topic/62358-engine-dampers/?&page=2#findComment-578115 Share on other sites More sharing options...
