I have a 71 240. Problem I'm having is it seems like my clutch is always engaged. It's almost impossible to get it into either first or second gear unless the car is off or rolling. In first and reverse with the clutch fully depressed the car rolls forward or back as if I'm letting off the clutch. Also theres a good clunk with the initial shift into reverse. I've replaced the master cylinder slave cylinder looks in good shape no leaks. I have the adjustable shank on my slave cylinder so I tried to thread it out thinking it would improve and it did the exact opposite, so I threaded the shank all the way back to the point where it is just barely (not even 1 ft lbs) touching my clutch fork and still I'm having the same issue. System has been bleed completely and I cant take anymore away from the shank on the slave cylinder. Later I will try adjusting the clutch pedal from under the dash see if that gives me any improvement. Any advice or suggestions would help thanks for the read!!!!!!
https://www.classiczcars.com/forums/topic/62380-clutch-not-fully-disengaging/
I just purchased the vehicle it has always done it in my case but I dont know for how long. A friend recommended a test I can do to see if it's the just clutch itself needs replacing so when I get home I'll try that and know a little more
No I'm unaware if it has been replaced. I'm thinking that the problem is my clutch itself after talking to some friends. I think I'm going to order a clutch kit and see where that take me but what could be the other causes you speak of
  On 6/24/2019 at 6:57 PM, siteunseen said:
I've bought 2 Exedy 6009 kits from Amazon. Great clutch for around $100. Fyi
That was going to be my next question after I did some googling lol thanks!
When you do the clutch be sure the throw bearing and collar stack to the proper height. Maybe some one can link to it for you. If the stacked height is wrong it can cause similar issues
  On 6/24/2019 at 7:43 PM, siteunseen said:
Are you using the OE 4 speed or has it been swapped out for 5 gears? That's where the collar heights come into play.
Oe 4 speed
  On 6/24/2019 at 7:48 PM, Mark Maras said:
 Did you try lengthening the master cylinder rod to clutch pedal yet?
No I havent tried that yet but I get a good pedal so I'm not sure if that would be the issue. Also I dont want to adjust it and then have to figure out how to get it back to where it is if that isnt the issue
The master cylinder that I replaced looked to be original and I set the new one to the exact same length so I'm kinda thinking that wouldnt be the problem as much as the clutch itself
