Posted June 24, 20195 yr comment_578282 I knew this was there just didn't know how severe it was until today. Had my exhaust tweaked a little better and while up on his lift I took some photos. Passenger's seat has one all the way through. It had leaked out the heater cores water c o c k for years apparently and caused this. Will new floor pans take care of this? Thanks in advance. Cliff Driver's side, not as bad... Rest of it... Edited June 24, 20195 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/62382-rusty-hole/ Share on other sites More sharing options...
June 24, 20195 yr comment_578284 Cliff, If it were mine, I would only replace the places in the floor with patches that need it and replace the rusty frame rails. Now if you get it cleaned up and you find a lot more holes I might change my mind but on the car I am doing know that is what I did. I might have a partial floor pan from Charlie that would have the section you need. You would also need to get some frame rails. I'll be in "T-town" on Thurs evening until sometime late Friday Afternoon. If you wanted to try to meet up. I know you're pretty far North of I-20 Link to comment https://www.classiczcars.com/forums/topic/62382-rusty-hole/#findComment-578284 Share on other sites More sharing options...
June 24, 20195 yr Author comment_578289 Yep, frame rails are nice and beat up. First I'm going to fill that hole in with something yet to be determined (I'll have to do my homework). I may just leave it as is and sale it right before I kick as an original survivor. Hopefully we'll stay out of harms way? Tuscsloosa is about 2 hours from my house down a pot hole filled interstate I-59. I believe I'll wait until Tennessee ZCON next year to see you and Cody. Thank you though! Cliff Link to comment https://www.classiczcars.com/forums/topic/62382-rusty-hole/#findComment-578289 Share on other sites More sharing options...
June 24, 20195 yr comment_578292 No problem Link to comment https://www.classiczcars.com/forums/topic/62382-rusty-hole/#findComment-578292 Share on other sites More sharing options...
