Parking Brake Cable Hangers - Broken
SoCalJim
Both of my parking brake cable hangers are broken, allowing the cables to lay on the u-joints of the stub axles.  Do any of you know a source for replacement parts or have a nice solution to replacing these?  Thanks!
Edited by SoCalJim
Greetings fellow member of the Jim club.
Me thinks the material used is very similar to the bargain basement style exhaust hanger parts I see at the local auto parts emporium. Now I think the original parts come with and installed on (ie threaded through), a new OEM cable, which makes it a bit tricky to apply "new" ones should you be able to fabricate or buy some.
I may have a slightly used cable with these items still attached for reference.
Thanks Jim!  I’m proud to be a member of the Jim club!
My neighbor had some 1/8” rubber sheet, so we cut a bunch of pieces to size, punched holes in the pieces, and stacked 4 pieces to make up each side.  I think this can only be a temporary solution, as the original material was layers of rubber with woven strands in it.  I’ll take a look at exhaust hanger parts and see if I can find something better than what we cobbled together yesterday.
Thanks again, Jim!
Edited by SoCalJim
Extraneous word edited out
 A piece from the side wall of a tire might work.
