F54/P79 Swap Project
Might that be one of our resident racers @Jeff G 78 ? Seems like the kind of thing he'd be all over.
I also found another error source... If you look carefully at the piston design, you'll see that the tops of the pistons don't actually touch the cylinder walls. There's a small gap between the piston tops and the walls. You can see the effect of this by the carbon ring left at the tops of the cylinders where the rings don't scrape. Nothing scrapes there because there's no contact.
I measured the volume of that area to be about 0.63 cc. Doesn't sound like a lot of volume, but since it's uncompressed, it changes the compression ratio by almost 0.1.
So if you're at 8.9 and want to get to 8.8, you can account for that.
I'm at 8.83 on my spreadsheet and am about to call it a day. Now I need to find someone who's measured the P79 volume AFTER they cut the head.
Edited by Captain Obvious
Fixed the wrong tagname
From the great Brian Little:
" The one on the right is a P79/P90/P90a chamber. It's actually larger/deeper in volume than the N42/47 at 53.5cc. Compared to an open chamber design you can see how the flattop piston "quenches" the mixture into the sparkplug as it reaches the top of it's stroke. This is a pretty standard shape for most modern heads. The photo is after shaving it .080", I measured it at 46cc in volume. Note the extra water hole on the bottom right vs the N47. "
Source: http://datsunzgarage.us/p79/
  • Who's Online   0 Members, 0 Anonymous, 997 Guests (See full list)
