September 13, 20195 yr comment_583886 Wait until about 7p.m. That's when things start getting fuzzy. When I did #3 it was just about impossible to get the sprocket on the cam. Everything was new. Link to comment https://www.classiczcars.com/forums/topic/62385-f54p79-swap-project/?&page=7#findComment-583886 Share on other sites More sharing options...
September 14, 20195 yr Author comment_583909 11 hours ago, 240260280 said: You can adjust the slack side guide inward at the top to take up all the chain slack so that the tensioner goes back. I completely forgot about that. I had talked about it before, but by this time, my brain was full. So I slotted mine some and it's almost back to where it should be. I'm confident with a new set of non-worn guides, I'll be able to make that work fine. Thanks for the reminder!! Link to comment https://www.classiczcars.com/forums/topic/62385-f54p79-swap-project/?&page=7#findComment-583909 Share on other sites More sharing options...
September 14, 20195 yr Author comment_583910 7 hours ago, siteunseen said: When I did #3 it was just about impossible to get the sprocket on the cam. So now I'm not sure if your kidding or not... You do know that the timing hole you use has absolutely no effect on how tight the chain is, right? Haha!! Link to comment https://www.classiczcars.com/forums/topic/62385-f54p79-swap-project/?&page=7#findComment-583910 Share on other sites More sharing options...
September 14, 20195 yr Author comment_583911 Oh, and I'm not worried about the valve timing. I've got a lathe and I've already verified that I can set-up to bore the locating pin hole: I didn't cut any metal yet, but if I need to, I can adapt to the offset bushings. Link to comment https://www.classiczcars.com/forums/topic/62385-f54p79-swap-project/?&page=7#findComment-583911 Share on other sites More sharing options...
September 14, 20195 yr comment_583912 Don’t worry about chain slack, go for the CR you want . Move the guide to take up slack. Advance cam timing a bunch and roll with it! I have .050+ off my e88 , no shims . Plug in 39cc chamber numbers for the MN47! I got my fingers crossed for my engine . Link to comment https://www.classiczcars.com/forums/topic/62385-f54p79-swap-project/?&page=7#findComment-583912 Share on other sites More sharing options...
September 14, 20195 yr comment_583913 Generally, as I understand things, advancing cam timing moves the power band to lower RPM. A bit ironical because it means that as the engine gets more miles it makes more power at higher RPM. Where it should spend less time due to wear and age. Might be why Nissan added the two extra holes. I'd think that you'd want to degree the cam to perfection, to where the cam builder has designed it. Low RPM grunt can feel like more power. Might also be more detonation prone though.. You need to build a dyno. Link to comment https://www.classiczcars.com/forums/topic/62385-f54p79-swap-project/?&page=7#findComment-583913 Share on other sites More sharing options...
September 14, 20195 yr comment_583926 7 hours ago, Captain Obvious said: So now I'm not sure if your kidding or not... You do know that the timing hole you use has absolutely no effect on how tight the chain is, right? Haha!! The book I have says use the higher numbers for chain stretch. Try it and see, all you'll loose is a zip tie. Link to comment https://www.classiczcars.com/forums/topic/62385-f54p79-swap-project/?&page=7#findComment-583926 Share on other sites More sharing options...
September 14, 20195 yr comment_583930 The book I have says use the higher numbers for chain stretch. Try it and see, all you'll loose is a zip tie.Interesting. When I moved my sprocket from 3 back to 1 is when I noticed I could hear chain slap on the cover as the motor decelerated from a rev up. I think moving the sprocket only tightens or loosens the right right (upward side when running) of the chain and pushes the slack to the tensioner side where it is supposed to taken up by the tensioner. The tensioner can only take up so much. This is my guess. Someone feel free to shoot my theory down, I’m still on my first cup of coffee this AM [emoji477]️Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/62385-f54p79-swap-project/?&page=7#findComment-583930 Share on other sites More sharing options...
September 14, 20195 yr comment_583931 @siteunseen @Captain Obvious I believe both of you to be correct. Adjusting the Cam Sprocket makes the chain feel tighter and more difficult to install on the Cam nose; so it seems like taking up the slack when doing the operation. It however, puts more chain on the slack side of the assembly. Moving the chain guide inward takes up the slack by making the chain run along a longer path. btw when moving the cam spocket, it is ok to turn the cam a degree or so as needed to help get the sprocket back on the cam nose. Edited September 14, 20195 yr by 240260280 Link to comment https://www.classiczcars.com/forums/topic/62385-f54p79-swap-project/?&page=7#findComment-583931 Share on other sites More sharing options...
September 15, 20195 yr Author comment_583991 Actually I am completely confident that I am 100% right and 0% wrong. Changing the cam gear to a different index hole has absolutely nothing to do with chain tension. It changes relative teeth position, but not chain tension. This is what the different index holes do... They change the relative position of the gear teeth to the hole. (Which changes the relative position of the teeth to the cam lobes.) But it does nothing to the overall tension on the chain. Remember this pic? : The reason they say you can use a different hole to account for chain stretch is ONLY to bring the valve timing back into spec. It won't tighten up the chain any... That's the tensioner's job. Link to comment https://www.classiczcars.com/forums/topic/62385-f54p79-swap-project/?&page=7#findComment-583991 Share on other sites More sharing options...
September 15, 20195 yr Author comment_583992 Here's another way to think about it... Within a small amount of manufacturing tolerance, the centerline axis of the cam gear must always be on the same axis as the camshaft. It if weren't, the gear would wobble eccentric and make the chain tighter in one spot and looser in another. If changing to a different indexing hole is expected to have an effect on the chain tension, then what happens when you rotate the cam 180 degrees? Does it get extra loose? Link to comment https://www.classiczcars.com/forums/topic/62385-f54p79-swap-project/?&page=7#findComment-583992 Share on other sites More sharing options...
September 15, 20195 yr comment_583993 There is less chain under tension on the tight side and more on the slack when you take up the slack (as mentioned above). You can tighten by one whole link if you want to push to more easily understand what I mean and why @siteunseen found moving the sprocket to seem like it tightened and took up slack. Don't think of it as quantized to number of links. Edited September 15, 20195 yr by 240260280 Link to comment https://www.classiczcars.com/forums/topic/62385-f54p79-swap-project/?&page=7#findComment-583993 Share on other sites More sharing options...
