Posted June 30, 20195 yr comment_578719 Hi guys, Working on a 1974 260z and ran into another weird lighting problem. The brake lights work as intended with the running lights off, but when the running lights are switched on, hitting the brake pedal does not brighten the rear lights. I checked the bulbs and the brake light bulbs are indeed dual filament like they should be. The odd thing is that when the running lights are switched on, both filaments are lit, that shouldn't be the case right (assuming one filament is for brake lights and the other is for running lights)? Any ideas as to how to get the brake lights to engage with running lights on? Link to comment https://www.classiczcars.com/forums/topic/62413-brake-lights-not-engaged-with-running-lights/ Share on other sites More sharing options...
June 30, 20195 yr comment_578725 Post photos of the inside of the sockets and the bulbs you pulled out of them. Do this for all the sockets in each taillight housing. Otherwise, all you will get here is speculation. Link to comment https://www.classiczcars.com/forums/topic/62413-brake-lights-not-engaged-with-running-lights/#findComment-578725 Share on other sites More sharing options...
June 30, 20195 yr Author comment_578729 On 6/30/2019 at 11:39 AM, SteveJ said: Post photos of the inside of the sockets and the bulbs you pulled out of them. Do this for all the sockets in each taillight housing. Otherwise, all you will get here is speculation. Will do - it's my friend's car so the next time I'm at his place I'll grab some shots. Link to comment https://www.classiczcars.com/forums/topic/62413-brake-lights-not-engaged-with-running-lights/#findComment-578729 Share on other sites More sharing options...
June 30, 20195 yr comment_578736 Hey cats, my 1975 280Z brake light wiring is very straightforward according to the description in my Factory Service Manual. Power flows from the battery to the black fusible link, through the shunt, through connector C-6, through a 10A fuse (right row, center fuse), through connector C-2, through the stop lamp switch down on the pedal box, back through connector C-2, on to the Body Harness connector that’s outside/behind the passenger seat, and on to the connectors at each rear combination lamp assembly. Or more simply, from battery, through a fuse, through the stop lamp switch, and on to the brake lights. Nowhere should it tie into the parking lite circuit, turn signal circuit, or hazard circuit. You may have some creative wiring in your car to uncover and sort out. I still have to double check my actual wiring harness to verify everything I just told you is correct. good hunting! Edited June 30, 20195 yr by SoCalJim Minor grammar mistake Link to comment https://www.classiczcars.com/forums/topic/62413-brake-lights-not-engaged-with-running-lights/#findComment-578736 Share on other sites More sharing options...
July 1, 20195 yr comment_578770 If you switch your alarmlights a few times on and off.. it's might be possible they work again.. the alarmswitch has many connections involving the brake and direction lights cables.. A euro car's alarm switch has only 4 or 6 conn. a USA model has 9 connections..! ( in a USA car the brakelight wiring go's through the alarmlights switch..) Link to comment https://www.classiczcars.com/forums/topic/62413-brake-lights-not-engaged-with-running-lights/#findComment-578770 Share on other sites More sharing options...
July 1, 20195 yr comment_578772 On 7/1/2019 at 8:24 AM, dutchzcarguy said: If you switch your alarmlights a few times on and off Hazard switch ? Link to comment https://www.classiczcars.com/forums/topic/62413-brake-lights-not-engaged-with-running-lights/#findComment-578772 Share on other sites More sharing options...
July 2, 20195 yr comment_578849 On 7/1/2019 at 10:41 AM, grannyknot said: Hazard switch ? Yes.. btw.. i didn't look into a elec. diagram but know there are a lot of wires onthat hazard switch..? Link to comment https://www.classiczcars.com/forums/topic/62413-brake-lights-not-engaged-with-running-lights/#findComment-578849 Share on other sites More sharing options...
July 3, 20195 yr Author comment_578902 Got an update for you guys: It seems the brake pedal has somehow been switched around such that when it is pressed, the running lights (side markers included) all turn on. When turning the running lights on via the combo switch and then hitting the brake pedal, all these lights brighten. We've been studying the FSM but are coming up empty here. Any ideas? -chase Link to comment https://www.classiczcars.com/forums/topic/62413-brake-lights-not-engaged-with-running-lights/#findComment-578902 Share on other sites More sharing options...
July 3, 20195 yr comment_578906 Side markers that brighten when braking?? Hahaha… somebody has made some changes in the elec. cables and you must have side marker bulbs with double connections on back? huh??? Link to comment https://www.classiczcars.com/forums/topic/62413-brake-lights-not-engaged-with-running-lights/#findComment-578906 Share on other sites More sharing options...
July 3, 20195 yr comment_578914 Most likely you have a single filament bulb in a dual bulb socket somewhere. That I why I asked you to take pictures of all of the insides of the sockets and base of the bulbs. Link to comment https://www.classiczcars.com/forums/topic/62413-brake-lights-not-engaged-with-running-lights/#findComment-578914 Share on other sites More sharing options...
July 3, 20195 yr Author comment_578919 On 7/3/2019 at 11:27 AM, SteveJ said: Most likely you have a single filament bulb in a dual bulb socket somewhere. That I why I asked you to take pictures of all of the insides of the sockets and base of the bulbs. Alright, I'll ask him to send over pictures. But do you mean that having single filament bulb where a dual *should* be would make a change as drastic as this to the way the car functions? Link to comment https://www.classiczcars.com/forums/topic/62413-brake-lights-not-engaged-with-running-lights/#findComment-578919 Share on other sites More sharing options...
July 3, 20195 yr comment_578921 Yes, because you are backfeeding the circuit. Link to comment https://www.classiczcars.com/forums/topic/62413-brake-lights-not-engaged-with-running-lights/#findComment-578921 Share on other sites More sharing options...
