Posted May 20, 200321 yr comment_38161 Hi guys,Another problem, I think it's to do with the carbs, and I have a feeling its something to do with running rich... but I dunnoAfter idling for a while (few minutes) my car goes up to 2000-2500 reasonably OK, but then splutters and chokes and has a hard time going any higher. Once he's being driven for a while it returns to normal and he'll rev freely.I was idling for a very long time on a slight decline and then drove off, only to be restricted by the car, which wouldn't go very fast at all - anyuthing above 2000 was sluggish and no power at all, I drove for a while (couple of kays) annoying everyone behind me, and then he ran perfect after that!What do you think could be the problem? Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/ Share on other sites More sharing options...
May 21, 200321 yr comment_38169 Have you looked at your fuel filter again?Sounds like it may have picked up gunk from the tank again! Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/#findComment-38169 Share on other sites More sharing options...
May 21, 200321 yr comment_38170 Mike is on probably right. Did you get to have a look inside the tank last time? Or check the lines? btw, please don't call your car a he. She's not into crossdressing you know. Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/#findComment-38170 Share on other sites More sharing options...
May 21, 200321 yr Author comment_38176 George - my Z is a male!!! If you want proof, just look at the bonnet! I had my tank dropped and inspected (no rust!) and my lines flushed last time. Strange thing is, I didn't even think it could have somethign to do with that :stupid: I'll check it after lunch! Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/#findComment-38176 Share on other sites More sharing options...
May 21, 200321 yr comment_38180 hey guys forgive my ignorance but now that the new thread option is gone how do i start a new thread? Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/#findComment-38180 Share on other sites More sharing options...
May 21, 200321 yr Author comment_38182 grrrrrr if you want to ask a question, make your own thread about it!!! Go to the forum, and then up the top there'll be a "NEW THREAD" button. Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/#findComment-38182 Share on other sites More sharing options...
May 21, 200321 yr comment_38184 Quote Originally posted by Alfadog George - my Z is a male!!! If you want proof, just look at the bonnet! Sounds a bit like my Norweigian Forest Cat, given to me as a female only to be discovered later as a male and still called her, she or it, but never him! Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/#findComment-38184 Share on other sites More sharing options...
May 21, 200321 yr comment_38185 Yeah Thanks Brett for asking the question. I had the same problem as well wondering how to start a new thread.Tried my first one the other day and it is still in cyberspace though. Ended up asking a question by piggy backing on to someone else.BTW - great response Alpha - you warped bas***rd:D Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/#findComment-38185 Share on other sites More sharing options...
May 21, 200321 yr Author comment_38186 I checked and fuel seems to be getting along fine. I'm pretty certain now that it's (safe way to refer to it I guess) running rich, you can see smoke coming out the exhaust (black) and its generally very stinky (I was standing around the rear for a while and my eyes started to hurt) I'm going to try to lean the mixture a bit, but first I have to work out how!!!! :stupid: Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/#findComment-38186 Share on other sites More sharing options...
May 21, 200321 yr comment_38195 Alpha,Su's don't go out of wack suddenly.How long has he [?] been running like this.If it's only just started, I would doubt that it's mixture.Pull the plugs and have a look see! Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/#findComment-38195 Share on other sites More sharing options...
May 21, 200321 yr Author comment_38199 I think it started a week or two ago... noticed it after a traffic light it stuttered once or twice... strange I thought maybe it's because I am running out of fuelNow it's a bit worse, where it goes on for longer and in lower RPMHard to tell when it started though...What am I checking the spark plugs for? Dirtiness? Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/#findComment-38199 Share on other sites More sharing options...
May 21, 200321 yr comment_38204 If the plugs are black & sooty, then it's either to rich or it could be ignition.Thats another common problem, point gap. Check that as well, after all if he is getting weak spark, then you get incomplete combustion and hesitation. Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/#findComment-38204 Share on other sites More sharing options...
