I joined this club at the end of December just after deciding to do something about the 240Z in my garage collecting spider webs and dust. I had always told myself that I'd eventually do something about it and figured if I didn't proceed with it there was no point keeping it. Being beyond the point of wanting to do much work myself I got the engine started (first time in about 4 years) and drove it to my regular mechanic for a little bit of work. Part of the deal was that they could work on it as time permitted; I was obviously in no hurry. I got it back today after waiting 5 months.
Here's a brief list of the parts replaced:
Engine rebuilt by <a HREF=http://www.jasperengines.com/gasengines.html>Jasper Engines</a>
Clutch kit (bearing, pressure plate, clutch disc)
Transmission seal front
Transmission seal rear
Water pump
Thermostat
Oil sender unit
Coolant temperature sensor
Thermostat housing
Thermostat cover
Carb floats
Carb rebuild kits
Engine mounts
Exhaust straps
Upper radiator hose
Lower radiator hose
Heater hoses
Battery
Drive belt
Spark plugs
Poly bushing kit
Tokico struts
Tokico springs
Front brake rotors
Front brake calipers
Front brake flex lines
Front brake pads
Real wheel cylinders
Rear brake flex lines
Rear linings
Front wheel bearing kits
Rear axle seals
Half shaft U Joints
Drive shaft U joints
Front tie rod ends
Lower ball joints
Spindle pins
Rear strut assembly
That last bit was because the left spindle pin popped right out. The right wouldn't even come out in a 2 stage hydraulic press.
I'll post a shot of the clean engine compartment as well as a picture of the car after being washed for the first time in about 15 years. I had planned on body work and paint next but after a wash and a little wax it doesn't look as bad as I was expecting. I might even go for one of those fancy detail jobs. A urethane airdam is on the way from MSA and I'll be ordering seat covers, carpet, plastic panels soon. I'll plan on posting more pictures as things progress. I did polish the valve cover and original slotted mags and I think they came out fairly good.
https://www.classiczcars.com/forums/topic/6246-finally-got-my-car-back/
