Posted July 7, 20195 yr comment_579170 my turn signals both suddenly went out, but hazards still work, i tried replacing the flasher relay and it did not help. i found that the turn signal fuse was blown so i replaced it, this did not do anything either, any suggestions? It's a 1979 280zx Link to comment https://www.classiczcars.com/forums/topic/62464-turn-signal-problems/ Share on other sites More sharing options...
July 21, 20195 yr comment_580024 Currently having the same issue with my 1981 280ZX. And still working on it. I'm working under the dash, driver side. I had mice in my engine bay but they didn't eat up wires since wire sheathing is not made from vegetable matter. This is a current issue so I hope to share with you my findings. Link to comment https://www.classiczcars.com/forums/topic/62464-turn-signal-problems/#findComment-580024 Share on other sites More sharing options...
