Posted July 9, 20196 yr comment_579269 on my 280zx 10th Anniversary model one of the headlight jets leaks , causing the washer fluid to leak out on the headlamp - What do I need to do to stop it from leaking , do I have to replace the jet/nozzle? I guess I could empty the fluid container but I want to use the washer. Thanks Edited July 9, 20196 yr by H. Roeckelein Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/ Share on other sites More sharing options...
July 9, 20196 yr comment_579278 On 7/9/2019 at 8:43 PM, H. Roeckelein said: on my 280zx 10th Anniversary model one of the headlight jets leaks , causing the washer fluid to leak out on the headlamp - What do I need to do to stop it from leaking , do I have to replace the jet/nozzle? I guess I could empty the fluid container but I want to use the washer. Thanks I suspect it is the pump leaking not the jet Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/#findComment-579278 Share on other sites More sharing options...
July 11, 20196 yr Author comment_579388 On 7/9/2019 at 10:52 PM, Patcon said: I suspect it is the pump leaking not the jet Only one nozzle/jet leaks/omits fluid . if it was the pump I would guess both nozzles/jets would leak?? Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/#findComment-579388 Share on other sites More sharing options...
July 11, 20196 yr comment_579389 Not a zx owner but a car owner with wiper washers. Tootpick in the nozzle then check the old lines for cracks. Unhook the nozzles and plug the lines. Look for leaks? Spitballing only. Good luck. Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/#findComment-579389 Share on other sites More sharing options...
July 11, 20196 yr comment_579398 On 7/11/2019 at 6:15 PM, H. Roeckelein said: Only one nozzle/jet leaks/omits fluid . if it was the pump I would guess both nozzles/jets would leak?? Not if that one is closest to the pump and the line goes up somewhat from there. The jets are really just open holes on the end of the line. I would expect the pump to be what determines if fluid comes out or not. Admittedly I have touched one in a long time Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/#findComment-579398 Share on other sites More sharing options...
July 12, 20196 yr Author comment_579467 Thanks , sounds logical - I did have to replace my old pump did it with a used one so that could be my problem, although in the service manual it reflects a "T" valve which connects the pump hose and then the left and right headlight washer hoses, could this valve be my problem or is this just an open "T" valve??? Edited July 12, 20196 yr by H. Roeckelein Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/#findComment-579467 Share on other sites More sharing options...
August 24, 20195 yr comment_582536 Hi, I have a 1982 Datsun 280XZ with the passenger side headlight washer nozzle that has the same slow leak. The pump is likely the culprit. The reason is that the hose from the pump goes almost straight downward to a "T" where it splits to the left and right headlights. I suspect the reason the right leaks and the left doesn't is because of the long run, relatively, to the right headlight nozzle. There is enough mass to push fluid out of the right nozzle. To validate I took off the pump outlet hose and the pump outlet was leaking. I will purchase a new pump. Did you already figure yours out? Edited August 25, 20195 yr by John B Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/#findComment-582536 Share on other sites More sharing options...
August 25, 20195 yr Author comment_582559 leak was on the drivers side headlight and has stopped leaking - Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/#findComment-582559 Share on other sites More sharing options...
August 26, 20195 yr comment_582655 Thanks. Does anybody out there have a 1982 Datsun 280ZX Headlight Washer Pump for sale? I found an iffy one on eBay, a $140 rebuilt one on ZCarSource.com without picture, and one on ZParts.com for $125, but their order page is "broken" and I don't know if this is a reliable web site. I appreciate any help. Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/#findComment-582655 Share on other sites More sharing options...
September 8, 20195 yr comment_583527 The headlight washer pump on my 83 ZXT died years ago. Since I regard this as in contention for the most useless feature ever installed on a passenger car, I have cheerfully ignored it. There's a similar feature on my 2008 BMW 328ix Sportwagon, and the driver's side nozzle kept leaking and depleting the washer fluid. I noticed that it only leaked for a couple of hours after the system activated (automatically) so I pulled the fuse for the headlight washer. Now the headlight washers don't work when I wash the windshield, and they don't leak. And when I wash the windshield, I do the headlights. Edited September 8, 20195 yr by Pilgrim Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/#findComment-583527 Share on other sites More sharing options...
September 8, 20195 yr comment_583531 Thanks Pilgrim. I enjoyed your post. I'm almost where you are, but not quite - sentimentality I guess. Eric, from ZParts is checking on one for me. That looks like the end of the line! And I agree it is a useless feature. Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/#findComment-583531 Share on other sites More sharing options...
September 9, 20195 yr comment_583573 Let us know what it costs. Maybe I'll be inspired to make is functional. Don't bet heavily on that.... Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/#findComment-583573 Share on other sites More sharing options...
