December 18, 20195 yr comment_589546 Just a quick update. Eric from Parts never followed through. I've given up. Now I have an ECU problem! No one programs them anymore. Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/?&page=2#findComment-589546 Share on other sites More sharing options...
December 18, 20195 yr comment_589559 John, there are used Z parts sources, and they're well worth checking. ECUs also are available, and it's more practical to replace than to try and re-program. Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/?&page=2#findComment-589559 Share on other sites More sharing options...
December 18, 20195 yr comment_589561 Thanks Pilgrim. I've researched several sources (e.g, Jim Wolf, Z Car Source), but my problem is I have a rising rate fuel regulator plus a lot of other upgrades such as Turbonetics T3/T04B Hybrid Turbocharger, Intercooler, Adjustable Boost, Cold Air Induction, Limited Slip Differential, No Catalytic Converter, and Performance Exhaust. The people I've contacted say their standard ECU's likely won't work with the rising rate fuel regulator as the ECU's only work with 1:1 ratio. Not sure what I'm going to do except keep researching. Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/?&page=2#findComment-589561 Share on other sites More sharing options...
December 19, 20195 yr comment_589574 If you have lots of mods the stock ECU won't work. You will have to move to an aftermarket EFI system Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/?&page=2#findComment-589574 Share on other sites More sharing options...
December 19, 20195 yr comment_589589 Thanks Patcon. Do you have an aftermarket recommendation? Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/?&page=2#findComment-589589 Share on other sites More sharing options...
December 19, 20195 yr comment_589606 Depends how DIY you want to be. Mega squirt being the most DIY Several guys here on the forum are going Haltech Haven't laid hands on either Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/?&page=2#findComment-589606 Share on other sites More sharing options...
December 20, 20195 yr comment_589629 Thanks for the info Link to comment https://www.classiczcars.com/forums/topic/62475-headlight-washer-jetnozzle/?&page=2#findComment-589629 Share on other sites More sharing options...
