Posted July 22, 20196 yr comment_580125 I haven’t been able to find a list of parts needed for this HP goal. My real goal is 250-300 using an L28 without a turbo. But if this isn’t plausible in my case I’ll do what everyone else is doing. Get an L28et. My question/request for anyone looking at this is to supply me with a list of parts needed for this goal and if it’s even possible to get to 250hp cheaply Link to comment https://www.classiczcars.com/forums/topic/62533-300hp-out-of-l28-non-turbo/ Share on other sites More sharing options...
July 22, 20196 yr comment_580126 Best to go with a Scarab V8 which will get you to at least 250 hp. Link to comment https://www.classiczcars.com/forums/topic/62533-300hp-out-of-l28-non-turbo/#findComment-580126 Share on other sites More sharing options...
July 22, 20196 yr Popular Post comment_580130 On 7/22/2019 at 12:54 AM, 240zSean said: I haven’t been able to find a list of parts needed for this HP goal. My real goal is 250-300 using an L28 without a turbo. But if this isn’t plausible in my case I’ll do what everyone else is doing. Get an L28et. My question/request for anyone looking at this is to supply me with a list of parts needed for this goal and if it’s even possible to get to 250hp cheaply This is doable with a 3 liter motor but it takes about 12k to do it unless you are a very gifted engine builder. The head work alone is about 2-3k of that. Rebello or Datsun Spirit build them all the time but the real question is "How fast do you want to spend?" Very difficult for a DIY'er to hit those goals. These cars don't really need 300hp, an honest 200-225 makes them move really nicely without tearing the drivetrain and chassis up Link to comment https://www.classiczcars.com/forums/topic/62533-300hp-out-of-l28-non-turbo/#findComment-580130 Share on other sites More sharing options...
July 22, 20196 yr comment_580150 So Sean, agreed 100000% with Mr Patcon (at least I think he is a Mr! As for being a gentleman, the jury is out on that one)! :P My L28 with E88 head and mostly stock internals* + SU carbs is doing 232BHP / 210lbft. The tuner backed off @6400rpm even though the power was still climbing (he was afraid of it going too lean and melting a piston). From this point on each pony gets exponentially more expensive. The tuner tells me that with better top end fuelling / triples there is another 10-15% in there but that’s a lot of money for another, say, 20bhp. (By the time it’s fully rolling road tuned up I make it well over £2000 / $3000 additional spend). In all honesty the power I have is plenty enough for spirited driving on the public road and safely putting it ALL down. 60mph comes around in 5 seconds and the old lady regularly scares the pants off Subaru Imprezzas and other exotic machinery. But the greatest fun isn’t drag racing off the lights, it’s the lovely power around the twisty roads. Aim for a lovely beefy flat torque curve over headline BHP figures - you will enjoy it more and much more often, in any gear. My engine was built by very experienced chaps doing this for 40 years. They have built a 300bhp NA motor for their time attack machine (no diesel crank either). Don’t even think about what it cost them in parts, blood, sweat and time! Sadly they are all retiring :( As said already, the power in these engines is mostly made in the head. So time and money would be well spent there. Then there are the ancillaries that have to be matched, such as a decent ignition, exhaust system, carbs etc that make a huge and sometimes overlooked difference. There are a lot of very expensive carbs out there that are poorly set up, so budget for a decent amount of time / money on the Rolling Road with an experienced tuner. You could always head for Jenvey throttle bodies and EFI but then, as said before, it gets expensive. Good luck and watching your progress with interest. *Schneider springs / caps, 270 degree cam, 0.48” lift, fully ported head, flat top standard weight pistons 1mm over, larger 280 valves. Link to comment https://www.classiczcars.com/forums/topic/62533-300hp-out-of-l28-non-turbo/#findComment-580150 Share on other sites More sharing options...
July 22, 20196 yr comment_580155 L28 with 16psi on a turbo will get over 300hp at rear wheels Link to comment https://www.classiczcars.com/forums/topic/62533-300hp-out-of-l28-non-turbo/#findComment-580155 Share on other sites More sharing options...
July 22, 20196 yr comment_580159 These posts have come up before . Google 200 RWHP Hybridz and read so,e of those threads . 200 hp is much more realistic and if you haven’t driven a Z with 200 you don’t have the objectivity to ask for 300. 200 would be a hand full for a street motor. People that have ridden in my 155 rwhp car swear it’s much more. Gearing will help with the fun factor . The advice above is realistic. These engines aren’t cheap to get that HP goals . Cams, cam gears, harmonic balancers , pistons , valves , port work, hardware, engine control( ignition and fuel) , triples or EFI , $$$$$$$$$$$$$$$$ Link to comment https://www.classiczcars.com/forums/topic/62533-300hp-out-of-l28-non-turbo/#findComment-580159 Share on other sites More sharing options...
July 22, 20196 yr comment_580162 On 7/22/2019 at 1:15 AM, Patcon said: This is doable with a 3 liter motor but it takes about 12k to do it unless you are a very gifted engine builder. The head work alone is about 2-3k of that. Rebello or Datsun Spirit build them all the time but the real question is "How fast do you want to spend?" Very difficult for a DIY'er to hit those goals. These cars don't really need 300hp, an honest 200-225 makes them move really nicely without tearing the drivetrain and chassis up Well said Charles, but 300 hp is probably more like 20k plus....... 275C8E79-2576-48A6-8522-7995889F6CF7.MOV Link to comment https://www.classiczcars.com/forums/topic/62533-300hp-out-of-l28-non-turbo/#findComment-580162 Share on other sites More sharing options...
July 22, 20196 yr comment_580195 An S2000 has 247HP and a great sound between 7000 and 9000 rpm..... but a Z's torque is more memorable. Link to comment https://www.classiczcars.com/forums/topic/62533-300hp-out-of-l28-non-turbo/#findComment-580195 Share on other sites More sharing options...
July 22, 20196 yr comment_580197 Interesting. I am looking forward to having my engine dyno'd when done. It is a Stroker 3100cc out of @zKars old car and will have new life with a fuel injection system, Coil on Plug spark, Crank Angle Sensor and Haltech ECU. I am hoping to get close to these numbers with some fine tuning on the dyno. Link to comment https://www.classiczcars.com/forums/topic/62533-300hp-out-of-l28-non-turbo/#findComment-580197 Share on other sites More sharing options...
July 22, 20196 yr comment_580198 On 7/22/2019 at 6:30 PM, 240260280 said: An S2000 has 247HP and a great sound between 7000 and 9000 rpm..... but a Z's torque is more memorable. Having been one of the first 800 S2K owners in the country I used to love the bahhhhhhh above 6k rpm on EVERY drive. Then I drove my fiend’s BMW Z3M with the same headline 0-60 but that torque curve was just delicious! The Z is very similar in that respect. S2k was a motorbike on 4 wheels and you had to rag it everywhere to get the performance (and that was part of its charm). Z3M, any gear any speed would push you into your seat. Totally different ways to win your heart. Ask yourself what suits your driving best? High rpm / BHP and less low to mid range torque or good spread of torque and lower headline BHP? People buy BHP but drive torque! Link to comment https://www.classiczcars.com/forums/topic/62533-300hp-out-of-l28-non-turbo/#findComment-580198 Share on other sites More sharing options...
July 22, 20196 yr comment_580221 On 7/22/2019 at 7:00 PM, AK260 said: Having been one of the first 800 S2K owners in the country I used to love the bahhhhhhh above 6k rpm on EVERY drive. Then I drove my fiend’s BMW Z3M with the same headline 0-60 but that torque curve was just delicious! The Z is very similar in that respect. S2k was a motorbike on 4 wheels and you had to rag it everywhere to get the performance (and that was part of its charm). Z3M, any gear any speed would push you into your seat. Totally different ways to win your heart. Ask yourself what suits your driving best? High rpm / BHP and less low to mid range torque or good spread of torque and lower headline BHP? People buy BHP but drive torque! What year Z3M? Link to comment https://www.classiczcars.com/forums/topic/62533-300hp-out-of-l28-non-turbo/#findComment-580221 Share on other sites More sharing options...
July 23, 20196 yr comment_580249 On 7/22/2019 at 11:23 PM, Patcon said: What year Z3M?I can’t be too sure but it was either a ‘99 or a 2000 - it had the S50 engine with 316 ish BHP (IIRC). But what I recall the most is that lovely straight 6 torque laden bark. Link to comment https://www.classiczcars.com/forums/topic/62533-300hp-out-of-l28-non-turbo/#findComment-580249 Share on other sites More sharing options...
